http://www.bryant-unlimited.co.uk/RB1%20100
If you want a superb well-made lightweight rackcase in a variety of sizes, look no further than here. All aluminium so easy to drill, even cutting those pesky IECs out!
I bought the 1U 150mm to rehouse my Dlator, saving pounds in weight and a lot of space on top of the amp.
No affiliation, I just found them online and the service was prompt and professional too.
For UK and EU Dlator builders - a great rack case!
Re: For UK and EU Dlator builders - a great rack case!
Nice looking racks thanks for posting.
exactly what i was looking for, and for the same build, thanks for posting.
Thanks for the tip! How about some suggestion for in-expensive head shell with reasonable shipping to the EU? Like the grill cloth too, where did you get it?
Hi there, if you put your location in your profile it is easier to give specific help.jazbo8 wrote:Thanks for the tip! How about some suggestion for in-expensive head shell with reasonable shipping to the EU? Like the grill cloth too, where did you get it?
As for cabs, that is a combo cab and it was built by me from 18mm Baltic Birch ply. I learned to build them as cabs can be expensive to buy. I discovered it is not cheap building them either.
It is covered in black suede and diamond cloth from Taylor at Amplified Nation on here.
Unfortunately probably NOTHING connected with D style amps can be seen as cheap
That's the way of HAD, that's the way of here
I live in the UK and used this company for my D style head and matching speaker cab. I've since used the same company for other speaker / amp cabs and rate them very highly.
http://afcustomcabinets.weebly.com/
They'll build to your specs, see pics on site for examples. Reasonable prices if you are UK based.
