Thanks in advance for any responses ! So I built a 6v6 ods clone I used the dlite 22 as a guide for the build. I added the single tube reverb as well. The amp sounds great on the clean channel. The od channel seems bright and tin--ish so to speak. It doesent have the D style od more like an ocd pedal or jcm series marshall. I have experimented with slope resistor values and tone stack vaules. Im still missing out on the od sound.
I currently have apprx 183 volts on pins 1 and 6 of the od stage. I have the .01 and 100k I have 180k and .004 for the level and drive controls
2.2 and 2.7 with 4.7uf for the cathodes. I have tried numerous voltages on the 100k trim pot.
I have about 33ma bias on the 6v6's. for what its worth
od channel in 6v6 build sounds grainy
- lord preset
Re: od channel in 6v6 build sounds grainy
If you are running 6v6s your bias should be 18-22ma. 33ma would be more appropriate for 6l6.
vibratoking
yeah, LP is right. But you should really measure Va and Vk, decide how much power you want to dissipate and then set the corresponding current. Anything else is a guess that may or may result in your target being met.
Things are better
Thanks for all the suggestions, I rebiased for 6v6's and not 6l6
Some clips and pics would help. One man's grainy is another man's awesome.
