When measuring tube plate voltage should I measure between the plate and cathode or plate and ground?  Also, I assume readings are much higher at the plate pins with the tubes in vs. out.  I formed my caps and cranked up my clone today (tubes out) for the first time just to check the PS.  It seems to be working as expected.  I get readings from 503 at the power section progressing downward to 460 at V1 measured to ground.   I have a few more parts coming in soon to complete the build and will put the tubes in at that point.
Thanks,
whit
									Measuring plate voltage?
Re: Measuring plate voltage?
Measure between plate and ground. The difference between plate and cathode should only be a few mv different so it doesn't matter much. I like to clamp the black lead to the chassis ground so I can work with one hand for safety.
Your plate voltages should be very close across all the tubes since there's no current draw with no tubes. If you're getting a drop you must have the 150K FET resistor in place drawing a little current.
So far your voltages sound about right. The real test is of course when you get the tubes in.
