1) recommendations for setting the Phase inverter trimmer and OD trimmer.
2) Bias info? Never have biased a tube amp using the 4 jacks and a Multimeter method, have always used a bias meter which has two jack that go between the tube and amp and read two tubes simultaneously any info on how to use the multimeter method? Using the Bias king method how do you do it with 4 output tubes?
3) Biasing the FET, Looked at the 18v battery method and confused If i am not planning on hooking up an acoustic guitar do I really need to bias the FET?
4) Is it best to start up the amp the first time without the tubes and use a variac?
5) If I am powering up the amps without tubes I do not need a speaker hooked up correct?
6) is normal to see bright red flames bellowing out of the amp reaching the ceiling?
As always thanks from the rookie
