#124 power supply question
echo44
Post by echo44 »
Any recommendations of where to find the 300uF caps?
I have had no luck! I currently have two 80uF rated at 500V
that i was planning to wire parallel to have 160uF at 500V
but that may be cutting it close on the voltage? Any alternative ideas?
I have searched the usual sites and have had difficulties finding any 300 or 320uF caps?
ic-racer
Re: #124 power supply question
Post by ic-racer »
echo44 wrote:Any recommendations of where to find the 300uF caps?
I used these for my #124 a few years ago. Looks like they are still available new. http://www.tedss.com/2020003615
They are rated 290uf (-10/+50) and 300V.
dreric
Post by dreric »
In the past Ceritone has carried 320uf of good quality. 124 and 183 use these big values, there has been some debate about whether or not it's important.
Eric
Eric
1949 Zenith, Zenith Toggle Recoil, Zenith 55 & 440
amplifiednation
Post by amplifiednation »
Just go with 220uf...you will be fine, and they are available
Amplified Nation
www.amplifiednation.com
@ampnation
BorisG
Post by BorisG »
http://apexjr.com/capacitorsR.html Many capacitors ,parts there .He have more not listed.
