Master Volume in Effects Loop
JammyDodger
Hey All,
I would like to put a volume control between the effects out and in jacks. In this way I can set a 'balance' in volume levels between the Overdrive Volume and the Master Volume on the front panel then use the new control to adjust the amps overall volume. I'm sure this has been done before. I was thinking maybe a volume pedal could do it.
Any ideas on the the pot value should be?
Cheers, Mike
Cheers, Mike
The Jammy Dodger
Re: Master Volume in Effects Loop
That's what a Dumbleator is for.
Seriously, not hard to build and really improves the amp.
Why put a pot there. The master volume does exactly what you described in a non hrm. In a hrm, the levels are independent anyway.
I use a volume pedal with a 250k pot in it. Works great, almost colorless but it does take a little high end off. I can run the masters up at 12:00 and keep the volume reasonable.
JammyDodger
Bob,
Thanks - I'll try a volume pot (250) like the pedal. That's what I was looking for.
Cheers, Miek
Cheers, Miek
The Jammy Dodger
I was having some trouble with the post.JammyDodger wrote:Bob,
Cheers, Miek
I used 250k because that's what I have. I'm thinking that 1M may be a better match.
I second this question!jelle wrote:Why put a pot there? The master volume does exactly what you described in a non hrm. In a hrm, the levels are independent anyway.
JammyDodger
Maybe to clarify. This is an HRM model. I would like to be able to balance the levels between the HRM and the clean channel, then use another volume (pedal, pot, etc) to set my overall level.
Cheers, mike
Cheers, mike
The Jammy Dodger
HRM's are usually wired with two separate MV's, but I'm assuming you wired your amp with the global MV then? Look in the files section at the Bluesmaster HRM layout.JammyDodger wrote:Maybe to clarify. This is an HRM model. I would like to be able to balance the levels between the HRM and the clean channel, then use another volume (pedal, pot, etc) to set my overall level.
Cheers, mike
TM
JammyDodger
TM,
That's just it. I built the Bluesmaster HRM. I have two Master Volumes. I would like to put a pot in the effects loop to have a MASTER Master Volume. (or is that Master^2?)
Cheers, Mike
Cheers, Mike
The Jammy Dodger
Ahhh, the devil is in the details.......got ya now. Yeah, I guess it's the vol pedal then.JammyDodger wrote:TM,
Cheers, Mike
TM
Ah! Thanks for the clarification.
FWIW, all the HRM builds I've done for the past couple of years I've been using the traditional 'Ratio/Master' topology rather than the dual master. I use a 1M linear taper for the ratio and 1M audio taper for the master and there doesn't appear to be any significant impact on the HRM stack response as a result in the load alteration.
