Asian silver od reverb chassis
groovtubin
Post by groovtubin »
A friend got one, and it doesn`t have any mounting points, would someone kindly point me to the thread that addresses that issue? Thanks!
jim@Omegaamps
ToneMerc
Re: Asian silver od reverb chassis
Post by ToneMerc »
Jim, maybe this will help.
Mike
https://tubeamparchive.com/viewtopic.php?t=14060
crbowman
Post by crbowman »
I wound up making a very snug head cabinet with supports and then drilling through the sides of the chassis to mount.
groovtubin
asian chassis
Thanks guyzz!!
hapi building!!
dcribbs1412
Post by dcribbs1412 »
Jim
not sure if this would be an option
I used some aircraft nut plates...
http://www.ebay.com/itm/Aircraft-nutpla ... 43aea2f7b2
Fairly simple to install.
Darin
AtomCap
Post by AtomCap »
groovtubin wrote:A friend got one, and it doesn`t have any mounting points, would someone kindly point me to the thread that addresses that issue? Thanks!
jim@Omegaamps
how would you rate the quality of the chassis? too thin? hole size/position correct? or is it a basket case?
groovtubin
jim@Omegaamps
it`s not TOO bad, nuthin perfect, TAD on thin side...but i`m workin w/it w/o too much problem, you may NOT LIKE the fender type strap holes, .. pro`s, NICE WIDE CHASSIS, best yet if you ask me!!
I don't have this chassis but when I have to resort to using Fender strap type mounting I don't use the strap on top I just use the long bolts from the strap mount (can order just bolts) and use those fancy recessed washers on the top side. I always use a thin flat washer underneath the recessed washer so it doesn't cut into the tolex.
dcribbs1412
M Fowler wrote:I don't have this chassis but when I have to resort to using Fender strap type mounting I don't use the strap on top I just use the long bolts from the strap mount (can order just bolts) and use those fancy recessed washers on the top side. I always use a thin flat washer underneath the recessed washer so it doesn't cut into the tolex.
Hi Mark
If possible do you have a source for the "fancy recessed washers"
you can share?
Darin
Darin I just pick them up at local building center. I forget what they call those stainless steel washers. You could also use plastic washers as well.
EDIT
http://www.olsenindustrial.com/itemclas ... ng-Washers
dcribbs1412
M Fowler wrote:Darin I just pick them up at local building center. I forget what they call those stainless steel washers. You could also use plastic washers as well.
EDIT
Got it Mark
I was thinking the recessed flat bottom plastic ones like I got with a CE chassis a while back
Darin
Yes, finish washers.
The SS are better because they don't distort as easily when torquing down the screws.
crbowman
Post by crbowman »
Structo wrote:Yes, finish washers.
That's great cuz I'm not getting nearly enough clean headroom out of my chassis screws!
:lol: :lol: :lol:
:lol:
Something I thought of because somebody here did it, was to just slide in the chassis on rails, then the back cover of the head holds it in. :D
Darin those plastic countersunk washers are available from McMaster.
http://www.mcmaster.com/#standard-count ... rs/=jzv847
scroll down to Nylon Countersunk Washers
