Thx Leftystrat for getting me back to this.
I disconnected the reverb B+ rail, I'll be damned if the amp didn't get back to it's original big sound. Reconnected the B+ rail, bottom dropped out. I've been looking in the wrong area completely.
Now the strangest part, I put the reverb tube back in and the reverb control acts like a gain for the entire amp.
I gotta dig out the reverb schem and see what's going on there.
Edit...
What a nightmare.
Turned out to be a bad filter cap on the reverb supply rail.
I have a B+ rail parallel to the preamp. Both come off the screen node, the preamp is 4 nodes of 22uF each, the reverb was 2 nodes of 22uF and 10uF driving an ECL86. The 22 supplies both the driver and return, the 10 supplies the screen on the driver.
I don't know what's wrong with the 22, but once I replaced it all the bottom came back and reverb depth increased dramatically, same intensity at 9:00 as I was getting at 2:00. I replaced the 10 with another 22 for good measure.
UNCLE...
I give up. This amp has served me so well for the past 6-7 years but right now, in sailors terms, fuckin fucker's fucked.
I have no idea what else to try. I've replaced everything in the clean pre.
I'm taking it off the bench for now.
Original post...
I have an amp I built about 6-7 years ago from a Peavey 2x12 hybrid, SS preamp 2x6L6 power amp. I've gigged with it steady for 5 + years and it's always been a big rich tone. I used a fairly standard high plate design, tweaked a tad to get what I wanted, HRM and one tube reverb with an ECL86.
Over the past few gigs I've been increasingly unhappy with the tone so I put it on the bench. I listened, no bottom at all and it sounded like it was through a 3" radio speaker.
1) connect to another speaker, same
2) Connect another amp to it's speakers, they're fine
3) Connect another preamp to the power amp in, sounds great
4) Connect the preamp out to another power amp, tarrible.
5) Swapped V1 with a known good tube, same
Then I started with the real stuff.
1) Swapped the cathode bypass caps on V1, new Rk at the same time, no change
2) Swapped the tone caps in spite of them testing good on a cap meter, no change
3) Swapped the V1B coupling cap
4) Disconnected the reverb circuit
5) Disconnected the PAB
6) Ran a jumper directly from the output cap of V1B to input cap of the PI
7) Checked all the tone pots
8 ) Disconnected the Jazz/Rock switch
I'm about to rip the preamp out and start over, but I thought I'd float this here first. I've never heard anything like this before.
The only conclusion I've made so far is that this is in V1A or V1B since I've bypassed everything else and testing the power amp with another preamp.
Thoughts?
