My Handmade "Bluesmaster/RIPPER Reverb" video
Hi,
Here is my bluesmaster/RIPPER with reverb amp
Its almoust ready
Greetings from Chile
http://youtu.be/rYkZ1L120oc
Its almoust ready
									Soy de Chile y tu?
						Re: My Handmade "Bluesmaster/RIPPER Reverb" video
Soy de Oregon.
Su amplificador suena bien.
Podemos ver algunas fotos de ella?
¿Es difícil encontrar piezas de amplificadores allí?
				bluesfendermanblues
Sounds really good!
Si cuesta bastante (pero la mayoria es importada)Structo wrote: Podemos ver algunas fotos de ella?
I use Classictone for all transformers and I was pretty much shocked about how good they sound over some "other" famous transformers
Some Pics:
[img:640:480]https://dl.dropbox.com/u/112924595/Cabl ... k%2010.JPG[/img]
[img:480:640]https://dl.dropbox.com/u/112924595/Caja%204.JPG[/img]
[img:640:480]https://dl.dropbox.com/u/112924595/Dumb ... lo%201.JPG[/img]
[img:640:480]https://dl.dropbox.com/u/112924595/Sold ... edneck.jpg[/img]
Soon more pics and videos
Its a modified Bluesmaster preamp, into a Ripper kind of OD channel into a one tube Reverb into a Fender Power Stage with Dumble Presence mod
Soy de Chile y tu?
So I changed the eq of the RIPPER (2nd Channel) from a jcm800 like into a bassman/jtm And BOY IT SOUNDS GOOD NOW
I,ve found that this is a 2 Clean Channel amp:
First is more a blackface sound
Second is more a tweed Overdrive sound
Both sound awesome
I,ve even added a switch for bypass the third stage cathode bypass resistor (820R) with A: none, B: 680n, C: 2,2uf for different tastes of bass/Fat/fuzzy bass notes
Both sound awesome
Soy de Chile y tu?
Do you have a schematic for this amp? Or one you started out with?
Looks interesting!
						Looks interesting!
Look at the second page of this thread & it has schematics and even references some editable SCH versions of the schematics:
https://tubeamparchive.com/viewtopic.ph ... c&start=15
Please NOTE that the schematics are a draft "idea" and not based on actually seeing a Ripper amp.
with respect, 10thtx
Richon,
How close is your amp to this schematic (IF you're willing to share?)
I attached an editable version that you can alter IF you want to.
With respect, 10thtx
standard bluesmaster preamp...
but 2.2K cathode first stage, 68K slope resistor
OD: 470K/470pF insteak of 470K/47pF
Power/PI : Fender based , not the Marshall values in NFB
this so far...
maybe some minor mods will come later , like bright caps in the masters volume in each channel... but it seems it isn't necessary
or different bright caps on first EQ.... i guess so
also maybe some values to the mixer of the reverb
PS: 500pF in the second stage (recovery) from grid is to have less highs from it?
this so far...
Soy de Chile y tu?
well,
the OD channel (the 3rd and 4th stages) well completely dumped... redesigned
I went with the OD way of overdriving the signal ... but changed the coupling caps and also (very important) the CATHODE resistors into a Trainwreck-ish third stage and a simple fourth stage , which in results gets me into more distortion than OD (which I kinda like)
Soy de Chile y tu?
I was thinking it sounds great, but not Dumble-like, then I read the rest of the thread. Very cool design, sounds unique.
