HAD Modded Princeton
boldaslove6789
Post by boldaslove6789 »
Just seen this on G-base:
Its a Dumble Moddded Fender Princeton
with a Showman Pwr and OT
Looks like a low plate 100k/100k plate's on v1 "Classic" stack
Removed the Trem circuit, added Mid control, added Master Vol
Line Out off V1
2.7k NFB resister
Link to listing:
http://www.gbase.com/gear/dumble-dumble ... lackface-a#
Here's what the listing says:
Description: For sale is a 1965 Fender® Princeton® blackface amp, rebuilt by Alexander Howard Dumble in September, 1972 in his Santa Cruz, CA workshop. The Princeton® combo amp was converted to a head, most similar in construction to a Fender® Showman® amplifier. Historically this amp was completed at the same time the first Dumble Overdrive Special was finished. The prototype overdrive special was shown to the original owner of this particular amp, on the day he was called to pick up this conversion. The original owner was a Santa Cruz graphic artist, responsible for introducing Mr. Dumble to using silk screening for the lettering that was from then on to appear on Dumble amplifiers. In the fall of 1994, Dumble borrowed this amplifier from the owner and showed it to Jackson Browne. Browne was rehearsing at the time at an MGM sound stage in Hollywood for the "Late For the Sky" tour. He liked the sound of the amp so much that he insisted on using it for the remainder of the rehearsal. Browne then ordered his first Dumble amp after the rehearsal, and it is well known that he has been a Dumble fan for many years, along with David Lindley who was also at the same rehearsal, and was a member of the band. The control knobs from left to right are volume, treble, bass, middle and pre-amp volume (overdrive). The original vibrato circuit was removed, and the vibrato pedal jack on the rear of the chassis is now a line-out jack. There are also 2 speaker output jacks on the rear. The amp produces lush clean tones with both volume knobs set evenly. Turn the 2 volume controls past 8 and you will get the overdrive sound that you would expect from a Dumble rebuild. Also included with the amplifier are two Fender® Bassman® cabinets converted by Mr. Dumble. One cabinet houses two Altec 417-8 12" speakers. The second cabinet has two 12" JBL-D120F speakers. The rear panel of each cabinet has the Dumble oval opening most often seen on later Dumble cabinets. Modification consists of a Showman® power amp and power supply conversion. Diode rectifier feeds the existing filter cap only doubled up on one section. This provides the B+ to the 4 6L6 power tubes driven by a Showman® phase inverter circuit. Plate resistors are slightly different values on PI (V2). There is also an adjustable bias control. The preamp is the stock 2 stage Fender® circuit (V1). There is a master control between the preamp and phase inverter. A middle tone control added and the tremolo was removed. there is a line out at V1b. The amp has a lot of clean power and the gain is moderate. With a medium pickup and the master turned down there is only slight preamp overdrive. COMPONENTS: The Showman® transformers used are the following: Output 0022897 manu. code 606-2-49 85 ohm output Power 022756 606 2273 Choke 022699 606-3-48 Tubes are (4) 6L6 and (2) 12Ax7
Last edited by boldaslove6789 on Wed Jun 13, 2012 8:27 pm, edited 2 times in total.
boldaslove6789
Re: HAD Modded Princeton
And more:
dcribbs1412
Post by dcribbs1412 »
Very cool...monster cabs
Thanks for sharing
212Mavguy
Post by 212Mavguy »
Sweet!
Very nice.
I drew up a layout with some questionable values such as cap on switch.
Also if bias resistor pair 220K can't see the resistors.
They are 100k per picture #6 thanks to Darin.
The other two plate resistors look like 47k & 51k.
dcribbs1412
M Fowler wrote:Very nice.
Also if bias resistor pair 220K can't see the resistors. The other two plate resistors look like 47k & 51k.
Cool Mark
looks like bias is 2 100k's in pic 6
Darin
Yes they are thanks Darin, too much staring got me cross eyed :lol:
boldaslove6789
Attached is what I've gleamed so far.
May need work, I included a MS Visio File too:
Last edited by boldaslove6789 on Thu Jun 14, 2012 10:13 am, edited 2 times in total.
stevlech
Post by stevlech »
Can this be verified? Some items in the listing seem odd.
Hahaha :lol: Nice one Greg and I worked so hard doodling today! :)
qtone
princeton
Post by qtone »
Yep considering I showed this to Greg at about 2 this afternoon or so..
Id say he knocked that right out..
I stumbled across this last night doing searches for anything new popping up.
I barely saw this as it was at bottom of list of things for sale.
Note the 100 watt transformer...!
Sneak into Greg's computer and send me his layout for the Ultra Phoenix and other mods he has added :lol:
boldaslove6789
M Fowler wrote:Sneak into Greg's computer and send me his layout for the Ultra Phoenix and other mods he has added :lol:
:) lol, Argghh Mark
If I told you I'd have to kill you. :twisted:
Besides, my keyboard is gooped.
talbany
Post by talbany »
Greg
Nice job!!.. Thanks for the layout
dcribbs1412
boldaslove6789 wrote:Attached is what I've gleamed so far.
Very Cool...nicely done Greg
qtone wrote:Yep considering I showed this to Greg at about 2 this afternoon or so..
Thanks for the research qtone
Darin
