P.I. voltage
P.I. voltage
Hi , I have 296V on inverting side and 291V on non inverting side in my #102 Clone!!!
should not be the other way?
Re: P.I. voltage
Check https://tubeamparchive.com/viewtopic.ph ... 211#145211, well covered.
Re: P.I. voltage
Have you tried a couple of different tubes and see how your voltages check out?
Bryan
Bryan
- David Root
Re: P.I. voltage
It can come out either way depending on the tube. If you try enough different tubes you'll get one that does. It really doesn't matter, so long as the tone is where you want it.
That's what the trimpot is for.
Re: P.I. voltage
Hi , I haven't another quartet of power tubes to put in to compare ,but the sound of amp I like it very much!!
the trimpot is already set and I don't think to invert this big voltage difference!
Re: P.I. voltage
We're talking about the PI tube.grtamp wrote:Hi , I haven't another quartet of power tubes to put in to compare ,but the sound of amp I like it very much!!
Bryan
Bryan
Re: P.I. voltage
Sorry ,I didn't understand!
I changed the tube but the voltage it's the same.
Re: P.I. voltage
Well that's kinda odd. I've never had 2 PI tubes measure out just the same. Just to be sure are you measuring the points like in the below picture? Your layout may vary a bit.
Bryan
Bryan
Re: P.I. voltage
The non-inverting side of the PI should have about 6 more volts than the feedback side.The 1st half should have a smaller plate load and a little more voltage..What do you get when you disconnect the GNFB..I also wouldn't rule out a bad trimmer..
Re: P.I. voltage
Sonic , yes , that is the point where I check!
Tony , I already close the chassis in the cab!! (I need for a live concert)
My trim is well setting , sinewave signal at the same amplitude in both side!
