183 BOM?
Re: 183 BOM?
I'm looking for that too ... does anyway have this BOM ??
Re: 183 BOM?
There are schematics and layout files in the Dumble Files section. You could write your own BOM in 20 minutes. If you are going to build one of these amps I would highly suggest going over the schematic and topology several times over anyway, it will be good practice.
Period correct BOM would call for some really scarce and expensive components, there are a few posts on sourcing NOS resistors and such, if you use the search function. Best of luck to you.
Re: 183 BOM?
Hehehehe, you guys don't really expect us to do all the work do you?
Start making lists and check availability at a place like Mouser.
You can make a Project list there before ordering.
I recommend you use all 1 watt resistors in the preamp, 3 watt in the power supply.
Vishay Dale RN65D mil spec for V1 & V2 plates.
Here is a sort of list I made a year or so ago.
https://www.mouser.com/ProjectManager/P ... 16f6138154
Re: 183 BOM?
ok ok, got it ! haha it was just a guess. Thanks for infos.
