Low heater voltage 124 classic (FIXED)
dcribbs1412
Post by dcribbs1412 »
Fired up new build...
heater voltages really low...2.1V
MC Twin iron ....using 2 100 ohm for CT
Darin
sonicmojo
Re: Low heater voltage 124 classic (FIXED)
Post by sonicmojo »
Darin,
Don't be offended but I'll start with the obvious. You don't have it hooked to a current limiter, do you? This has bit me before, especially at the end of a long day.
Bryan
fishy
Post by fishy »
Is that with or without tubes?
dcribbs1412
sonicmojo...no offense taken...I was in a hurry this morning, but no limiter...
voltage caught me off guard.
fishy...without tubes
Darin
How are you measuring the heater voltage?
ToneMerc
Post by ToneMerc »
Unsolder the PT filament leads and check for 6.3V straight from the PT.
TM
dcribbs1412
Structo wrote:How are you measuring the heater voltage?
Hi Tom
using AC setting and going across pins 4-5 to pin 9?
Darin
dcribbs1412
ToneMerc wrote:Unsolder the PT filament leads and check for 6.3V straight from the PT.
TM
Will do TM...didn't think of that thanks
Darin
ToneMerc
Post by ToneMerc »
It almost sounds like your sockets are wired to one half of the tap, you do have a resistor across pin 2 and 7 right?
TM
dcribbs1412
ToneMerc wrote:It almost sounds like your sockets are wired to one half of the tap, you do have a resistor across pin 2 and 7 right?
TM
TM
voltage reads 2.2V with unsoldered leads?
I have a 100 ohm from pin 2 to ground also one from pin 7 to ground
ToneMerc
Post by ToneMerc »
So that's straight off the two greens because it has no center (grn/yel) tap correct? I would say that your PT is the culprit then.
TM
dcribbs1412
ToneMerc wrote:So that's straight off the two greens because it has no center (grn/yel) tap correct? I would say that your PT is the culprit then.
TM
Yes off the 2 green's no CT....
Not sure what I did...but this is the 1st iron I've had bad
total bummer...
Darin
heisthl
Post by heisthl »
Just out of curiosity, what about the unloaded main primary voltages?
www.RedPlateAmps.com
dcribbs1412
heisthl wrote:Just out of curiosity, what about the unloaded main primary voltages?
Assuming I'm measuring right...411V
...do I have a DOA PT?
Darin
10thTx
Post by 10thTx »
The voltmeter has a new & good battery in it correct?
I only mention that because of getting "off" readings on an amp with a voltmeter (thinking it was the PT) only find the battery was bad. I've seen others on amp forums post doing the same mistake.
Just trying to rule that concern out.
With respect, 10thtx
