124 build pops when you turn it off.
gary sanders
Post by gary sanders »
Just started doing this.If you turn stand by off first it doesnt pop.
Re: 124 build pops when you turn it off.
Probably just the switch has arced and damaged the contacts Gary.
I switch my amp off the same way, just the power switch.
I leave the standby switch on play since that has DC on it and I figure the less I use it the better.
However, I do use it when I warm up the amp for about 20-30 seconds.
I also put a .001uF ceramic cap on my Standby switch to help the pops.
