Interesting tone
dcribbs1412
Interesting tone
Post by dcribbs1412 »
sorry if this was posted previously
not sure what amp is used, but interesting tones/technique...
volume seems low
http://video.google.com/videoplay?docid ... 0384436967
erwin_ve
Re: Interesting tone
Post by erwin_ve »
dcribbs1412 wrote:sorry if this was posted previously
volume seems low
Scott is one of the best out there. I know he has a bandmaster modded by H.A. Dumble but I have never seen he's using it on the road. He has done most of his gigs and clinics with Custom Audio amps and pasts years with Suhr, which is I believe is more plexi based.
How interesting this all is, it isn't Dumble...
husky
Post by husky »
volume seems low
He preferred head is still the handwired SH100. He does have an Ultra Bassman he used to use on a few tunes. Live these days for long trips he usually takes a Hot Rod Deluxe because of the size. He only uses the clean channel with a G12-65 and adds one more pedal for his solo stuff
______
John Suhr
www.suhr.com
husky
Post by husky »
volume seems low
______
John Suhr
www.suhr.com
dcribbs1412
Thanks for the info
Luthierwnc
Post by Luthierwnc »
Here is a picture of his rig:
http://www.scotthenderson.net/geartxt.htm
There is a send control built into the amp so I'm guessing it isn't a lot different than the active buffers we use. Whether it is driven by one of those tubes or discreet I can't say -- but there is definitely some post PI activity in the signal path. Good luck with your investigation, Skip
