PI adjustment PI - exists in other amps ?
jazzyjoepass
Can anyone tell me more about the PI adjustment pot? When did it start showing up on his amps? I only know of the Ampeg SVT having a PI pot. Can anyone tell me of any other amps that has this besides the Ampeg SVT?
Re: PI adjustment PI - exists in other amps ?
The PI balance control was a practice used mostly in HIfi amplifiers to control harmonic distortion products or THD..Some engineers looked at it as a kind of harmonic controller since balanced topologies don't generate much if any even harmonic distortion product, so there's no 2nd harmonic, Slight AC imbalance in the push-pull output stage means you get a 2nd harmonic distortion product that dominates over the 3rd which is arguably more desirable in the output section of a HiFi amplifier..Don't ask how this all relates to guitar amplifiers..
Do a search.. Been discussed to death here..
jazzyjoepass
Thanks Talbany. I've read some of the discussions here on PI. But what I want to find out is how many amp makers (limit this to guitar amps) had actually thought of putting in a PI adjustment besides Dumble and the Ampeg designers. I'm sure Dumble took a lesson from the Ampeg designers, because he mentioned about them.
AFAIK..Only Dumble and Ampeg..You will more than likely see them in many other amps presently and in the futureThanks Talbany. I've read some of the discussions here on PI. But what I want to find out is how many amp makers (limit this to guitar amps) had actually thought of putting in a PI adjustment besides Dumble and the Ampeg designers.
Yours Sincerely
Mark Abbott
Mark Abbott
Funny, I would have thought that even harmonics would sound good to our ears since the sound is thickened by adding a tone an octave up. Of course, I coiuld be way wrong on this....
