Spec's:
100w
NON-HRM 183/102 with EL34's
Built in 2 Tube Reverb
Built in Dumbleator
Switchable LNFB on V1 for 182 and 102 Voicing
2 Selectable Ftsw'able Boost's (either regular PAB or full tonestack lift)
Ftsw'able FET
Ftsw'able Effects Bypass (only bypasses the effect in loop)
Ftsw'able OD/clean Select
AFAIK the pwr trafo is a Mercury Mag Twin reverb pwr trafo, Plexi Output trafo.
Here's some clips that were thrown together today.
Wampler Faux tape echo in the Built in D-lator's loop
Ported D-style cab w/ a Celestion G1265 (8ohm) & an Eminence texas Heat (8ohm) @ 4ohms
Gibson Les Paul Standard Trad. w/ Wcr Darkburst Bridge pup:
http://youtu.be/kvFGgLHVuIc
1968 Telecaster Custom:
http://youtu.be/-a1ZsJkWYXM
[IMG:682:1023]http://i444.photobucket.com/albums/qq16 ... nGood1.jpg[/img]
