Caps across the diode in #183
grtamp
Post by grtamp »
In the #183 schematic; are essential the 0.01uF capacitors across rectifier diodes or you can do it without?
glasman
Re: Caps across the diode in #183
Post by glasman »
The .01uf are an old school trick to reduce switching noise that was common on early day diodes. Probably not really needed thes days if you are using decent parts. I prefer UF4007 for that position.
Back in the old days the practice was to put a 470K and .01uf in parallel with the diode in the string to reduce the noise and equalize the voltage across them.
About 5 miles south of I-94
www.glaswerks.com
Not everybody likes fast diodes though...
http://www.passlabs.com/pdfs/articles/powersupply.pdf
"Yeah, sure, rectifiers are important, after all, the AC has to get converted to DC, but I don't like the fast recovery types that some audiophiles have raved about. Fast recovery means that they withstand many amps and volts in a tenth of a few nano-seconds, something we don't see very often on the old 60 Hz AC line. They are essential element in switching power supplies, but for regular "linear" power supplies, I much prefer SLOW diodes, and we create them by placing small capacitor circuits across the diodes, which greatly reduces radiated noise."
Last edited by martin manning on Fri Sep 30, 2011 10:16 am, edited 1 time in total.
grtamp
Post by grtamp »
Thanks for your explanation glasman!!
