boldaslove6789
Post
by boldaslove6789 »
Well I thought I could try and give back to this forum instead of leaching all the time
A friend of mine's Dumble ODS 100w HRM w/ 6L6's serial # 177.
If I could give more info, I would, but I can't. Hope this helps though:
David Root
Post
by David Root »
Thanx guy! Don't see anything unusual there at a quick look. Do you happen to know what 12AX7s it came with originally?
boldaslove6789
Post
by boldaslove6789 »
Nope sorry, it was purchased used.
It had RCA 12ax7a's (Fender labeled short plate) in it though, and Raytheon labeled RCA black plate 6L6Ggc's
bepone
Post
by bepone »
carbon resistors all the way up, yeah! (my man)
are those filter caps, cheap chinese type? hm hm first time to see those
stevlech
Post
by stevlech »
Thanks for the shots!
HRM w/ caps on V2? Never seen that before.
glasman
Post
by glasman »
Whats up with the grid divider on V2B?
Yet another fumble to lock and load
Gary
About 5 miles south of I-94
www.glaswerks.com
glasman
Post
by glasman »
Actrually, looking at the PI, there is a LOT of diffences in that amp.
Check out the PI caps and the cathode resistor, looks like a 470. This is not your mothers Skyliner.....
EDIT - naw it is an 820, he just built it in worng
glasman on Thu Sep 29, 2011 8:37 pm, edited 1 time in total.
www.glaswerks.com
glasman
Post
by glasman »
stevlech wrote:Thanks for the shots!
There are even HRM Dumbles with V1B feedback loops. The one I have seen also have 250pf snubbers.
Gary
www.glaswerks.com
ToneMerc
Post
by ToneMerc »
bepone wrote:carbon resistors all the way up, yeah! (my man)
Yes, it's his typical usuage of Sprague Q Line(aka Beyschlag- Draloric) and Piher, both carbon film resistor types..
TM
ToneMerc on Thu Sep 29, 2011 10:04 pm, edited 1 time in total.
ToneMerc
Post
by ToneMerc »
glasman wrote:Actrually, looking at the PI, there is a LOT of diffences in that amp.
Yep, you definitely don't see Sprague 192's in them everyday.
TM
bluefireamps
Post
by bluefireamps »
Wooden sides on the chassis?
Tube Powered
boldaslove6789
Post
by boldaslove6789 »
bluefireamps wrote:Wooden sides on the chassis?
All amps around this serial number range have a 3 piece chassis and wooden sides (like Dumble #183 etc.)
dcribbs1412
Post
by dcribbs1412 »
Thanks boldaslove6789
did you have a chance to hear it?
if so how did it compare to anything you've built or heard here.
Darin
markusw
Post
by markusw »
Cool! Thanks a lot!
May you tell us what transformers it has?
Peace,
Markus
Post
by Structo »
Thanks Greg!
