3rd Generation Period Correct ODS 50W iron recommendations
telentubes
Post by telentubes »
Is there favorite iron to use for a new 3rd Generation Period Correct ODS 50W build, ala Talbany's layout? I'd probably prefer something readily availability (new production) and wonder what direction I should go for the best results. Any suggestions and sources would be greatly appreciated.
Thanks,
Telentubes
David Root
Re: 3rd Generation Period Correct ODS 50W iron recommendations
Post by David Root »
Use what HAD used, BF Bassman iron. Or, if you want a separate PT winding for the relay supply, instead of a separate relay supply PT, try a tweed Bassman PT.
Magnetic Components make the BF iron and Mojotone has the tweed stuff. Both make "modern" OT versions with 4, 8 & 16 ohm secondaries.
Mercury Magnetics also has both styles, but are expensive. Best bang for the buck is Magnetic Components, www.triodeel.com
sonicmojo
Post by sonicmojo »
Check this thread too. It has specific details of what MC transformers I used in my 50w 3rd gen build. I am going MC again for my next 100w 70s type build.
https://tubeamparchive.com/viewtopic.php?t=14982
telentubes
Thanks Dave and sonicmojo. I'll take a look.
