First off I wanted to say thanks to all the folks here at TAG, the wealth of info here is amazing.
I have done a couple amp builds in the past, a 5E3 and a 18W TMB, both combos. However, I am about to get started on a #124 build.
I figured, why not document the build a little bit and post some info here. Should be a great way to get feedback as needed too...
Anyways, the basic specs that I am going with:
CE Chassis
Magnetic Components Transformers
Low plate Skyliner preamp.
F&T filter caps, 6ps coupling caps.
1W xicon carbon film resistors in most places.
RN65s on plates and cathodes.
I don't have any actual pictures yet, but here a are a few CAD snapshots of a few board layouts:
diodes not shown in this pic...
I am going to machine the preamp, rectifier, and filter cap boards myself. I haven't finished the layout of the cap board yet, will post pics when it is done.
The relay supply and relay PCBs will be from expressPCB. I have left provision on the power supply board for an 7805 regulator and heatsink, as well as connections points and current limit resistors for the footswitch LEDS and the pilot LED. I figured it would be a little neater wiring to hook the pilot light up to the relay supply vs running the wires back to the power tube sockets.
I am expecting all my parts the end of this week. Hopefully I will start to have some real build pictures (and questions) soon!!!
Thanks,
Steve
