A Little Old Tube Amp
Crikey, 1,000 watts!
http://www.youtube.com/watch?v=C3_-2fUm ... re=related
[img:679:550]http://historische-elektronik.piranho.d ... age028.jpg[/img]
- glasman
Re: A Little Old Tube Amp
Those kind of voltages scare the crap out of me. I am guessing that the amps were built for commercials installations (theaters etc). The noise factor of the amp itself (blowers etc) would not be too practical for most uses.
I looked at building a 4CX250 or 300 bass amp at one time, but the forced air cooling and 2500Vdc on the plates was a bit much
Now there are a few conduction cooled tubes out there that may work for a mega audio amp. Imagine the size of the iron.....
About 5 miles south of I-94
www.glaswerks.com
www.glaswerks.com
Amps like those were used to power the personal speaker systems at drive in movie theaters.
The good news is if you slip while working on one you wouldn't live to tell about it.
My Daughter Build Stone Henge
I wonder if you have to wear a lead shield when working on it?
- glasman
Structo wrote:I wonder if you have to wear a lead shield when working on it?
And a ventilator. Those are Mercury vapor rectifiers and are mighty toxic (if they should break).
www.glaswerks.com
www.glaswerks.com
My neighbors would love it for me to build one
Do you think a hot plate would work to get it down to bedroom levels?
Is it HRM
The original surround sound.
Believe it or not there is a small fraction of the tube hi-fi crowd that it into these for home use.
Eric
Eric
Hi everyone, new here, been just reading for a long time, thanks for sharing your knowledge!
Check out the specs on this triode:
http://hawkins.pair.com/mexblast.shtml
I am sure you will like it's plate dissipation numbers!
Horacio
Horacio
Got a phone call from TAG member benoit one day to come over to the music store.
I get there and a guy has the largest tubes I have ever seen in his custom built amp. He fired the amp up for me and we talked to the guy for awhile, crazy high voltage. I can't remember the tube numbers though.
He was getting a very large case to haul it around in.
