3rd gen iron
				dcribbs1412
3rd gen iron
Looking to start ordering for a summer project
a 3rd gen style build based on Tonys info
wondering if this new PT from MC would do, opposed to the older non 5v tap, and using the 5v tap for relays...also less ma's 200 instead of 240
PT http://www.classictone.net/40-18073.pdf
not sure what the SS wire is for?
OT http://www.magneticcomponents.net/40-18 ... _Stock.pdf OT has M6 steel
PT is around $25 more..not sure if there would be any pros/cons
any suggestions would be appreciated
Darin
Darin
						Re: 3rd gen iron
I have a mess (like 25) of NOS PT from the 70's Fender 2 6L6 amps as seen in:
http://www.webphix.com/schematic%20heav ... tr_rev.pdf
Kind of perfect for the 70's builds.
I have the export version with the multitap primaries. It's the one on the left in the pictures.
If there's enough interest I'll put them up for sale.
				dcribbs1412
Re: 3rd gen iron
Nice dreric
how did you acquire them?
- David Root
Re: 3rd gen iron
I have one too, from dreric. They are good PTs. However note thay are designed for driving a full wave bridge rectifier, not a conventional full wave rectifier. They won't give you the voltage you need unless you use a bridge rectifier.
				dcribbs1412
Re: 3rd gen iron
Hi David
are you referring to drerics PT's
or the ones in my post?
Re: 3rd gen iron
I went with 40-18005 PT, 48-18001 OT (4/8/16), 40-18003 choke and found the F-313X at Onlinecomponents.com.
						- David Root
Re: 3rd gen iron
dcribbs, dreric's Bassman 70 Export PT, that is what they are, and they are real NOS too.
				dcribbs1412
Re: 3rd gen iron
Thanks Sonic
leaning towards those same iron choices
Darin
Darin
Re: 3rd gen iron
I got them from an older amp repair guy in the SF bay area, I forget his name. He got from Fender when they were closing amp manufacturing in Fullerton in the early 80's. There are the real (fender) Schumachers. Just before the red knob period.dcribbs1412 wrote:Nice dreric
He sat on the for years and I've sat on them for years, thinking about putting them up for sale.
eric
Re: 3rd gen iron
Darin the SS wire is the shield wire for the transformer.
It goes to chassis ground.
Re: 3rd gen iron
Is that the Rison (sp) guy that worked at Fender for years?dreric wrote:I got them from an older amp repair guy in the SF bay area, I forget his name. He got from Fender when they were closing amp manufacturing in Fullerton in the early 80's. There are the real (fender) Schumachers. Just before the red knob period.dcribbs1412 wrote:Nice dreric
eric
He puts stuff on ebay from time to time?
Re: 3rd gen iron
No, I honestly can't remember the guys name, it was 10 + years ago. He was moving and I got a deal (or so I thought LOL)Structo wrote:Is that the Rison (sp) guy that worked at Fender for years?dreric wrote:I got them from an older amp repair guy in the SF bay area, I forget his name. He got from Fender when they were closing amp manufacturing in Fullerton in the early 80's. There are the real (fender) Schumachers. Just before the red knob period.dcribbs1412 wrote:Nice dreric
eric
Eric
				dcribbs1412
Re: 3rd gen iron
Thanks Tom
and see how it goes
Thanks for the info guys
Darin
						I ordered some relay transformers so I'll get the 40-18005 PT MC ironDarin the SS wire is the shield wire for the transformer.
and see how it goes
Darin
