Four Button Footswitch
David Root
Post by David Root »
Is there a four button footswitch at a reasonable price or will I have to build my own? I would like to have brite, OD, PAB and mid boost on my next build.
heisthl
Re: Four Button Footswitch
Post by heisthl »
You can bolt 2 Marshall replacement 2 button boxes together or you can adapt a Marshall replacement 3 button from tubesandmore.com to a 4 button, just drill another 2 holes for the switch and the LED on the top and add a MIDI jack to the front. - here's an example layout:
www.RedPlateAmps.com
greenbottle
4 button box
Post by greenbottle »
I think you may find Weber sells a 4 button box. Just the box. I have no idea what the quality is like but it may be worth a look. Alternativly get a local sheet metal worker to duplicate one for you.
Alan
talbany
Post by talbany »
Speaking of Weber and not to derail but I hear Weber just discontinued all cabinets..
https://taweber.powweb.com/store/kits.htm
Luthierwnc
Post by Luthierwnc »
There has been a steady stream of surplus Ibanez 4-button boxes on EBay really cheap. They have LEDs and DPDT switches. sh
da Geezer
Post by da Geezer »
Luthierwnc wrote:There has been a steady stream of surplus Ibanez 4-button boxes on EBay really cheap. They have LEDs and DPDT switches. sh
This one didn't sell.....maybe contact the seller to see if he still has it(?)
http://cgi.ebay.com/Ibanez-IFS4X-4-Butt ... 2a10f34432
G
David Root
Thanx for all the tips guys, I'll see if I can locate one of those Ibanez, if not I might do what Henry suggests, I have a three button box.
glasman
Post by glasman »
David Root wrote:Thanx for all the tips guys, I'll see if I can locate one of those Ibanez, if not I might do what Henry suggests, I have a three button box.
Check ebay, there was one this morning from about $10.00.
Gary
About 5 miles south of I-94
www.glaswerks.com
jaysg
Post by jaysg »
The 1590DD is ~7" on the inside. That doesn't give you much room between switches unless you do it like that Ibanez, where they're not four in line.
David Root
I forgot about NOR/FET switch! Now I need a 5-button switch. Not sure if I can get five relay boards in the chassis, will have to do some measuring!
I guess I can put a 3 and a 2 together. Maybe I should just build a new one in a diecast box, with Carling switches, and have done with it.
glasman
Post by glasman »
David Root wrote:I forgot about NOR/FET switch! Now I need a 5-button switch. Not sure if I can get five relay boards in the chassis, will have to do some measuring!
Problem is you won't find a diecast box big enough for 5 buttons (I looked). I have been looking for an alternative for several weeks. You will need a box length of about 340mm with switch spacing of 70mm.
For a one off project, you can always buy the Marshall 5 button box and modify it to you needs. They are pricey, but it is an alternative.
Right now I am soliciting fabrication bids for 5 button boxes for my SOD II's. Suspect that I will have to pay out the a$$ for a local shop or buy a 1000 of them and I get them out of Asia.....
Gary
www.glaswerks.com
David Root
I was afraid of that. I could drop the brite footswitch but then you don't really want brite on in OD mode.
I can get five relay boards in the chassis in the right place so I would like to do five. I found a cheap 5 button switch on EBay, $24.95 but no LEDs, that might be worth a try, just drill LED holes, repaint it and rewire it. Fabricated, not diecast.
greiswig
Post by greiswig »
David Root wrote:I was afraid of that. I could drop the brite footswitch but then you don't really want brite on in OD mode.
...which is why my bright relay is piggybacked to the OD relay and shuts off in OD mode. Would that get you back to 4 switches?
-g
David Root
Maybe. I seem to recall something about that now that you mention it. Gary, is there any potential downside to that? What are the functions of your five buttons, if that's not a State Secret.
da Geezer
Post by da Geezer »
What about this as an option?
