OD/Clean
halfbackstrat
OD/Clean
Hey guys, i'm writing up the parts list for a 124 build, this would be my first Dumble Build.
Project is going great so far, i've spent the past few months researching the electrical physics related to valve amplifiers. I've been able to answer all the questions after extensive research and reasoned logic. But theres one thing thats confusing me about the 124.
The OD/Clean and PAB relay's. These are Footswitch controlled through the relay circuits, i understand this.
Now i realise there are switches on the back to switch to manual control, but where are the manual controls? As of course there are only 3 switches on the face of the Dumble.
I should mention i know this forum is frequented by real pro's and i feel a bit bad asking a question that is probably quite simple.
But i've had a good search online and i wouldn't ask if i wasn't totally stumped.
Thank you for any feedback you can give me.
Matt
Matt
Matt
Re: OD/Clean
Welcome! The switches on the back just serve as a substitute to actuate the relays when the foot switch is not plugged in. Or as a duplicate or override when it is. Notice how pins 2 & 4 on the foot switch jack are applied to the manual switches. Good luck with your build.
halfbackstrat
Re: OD/Clean
So if no XLR controller is connected then the manual position is Overdrive engaged and pedal is clean only?
Thank you for the warm welcome!
Matt
Re: OD/Clean
You may do both Boost and OD with either the manual switches or foot switches. SO you get clean, clean + boost, OD, OD + boost with fingers on back or feet on floor. They're each other, brother......
halfbackstrat
Re: OD/Clean
Right so the Pedal side of the switch is off, without the XLR plugged in. Thank you so much man.
Really appreciate you taking the time for a newbie like me.
Matt
Re: OD/Clean
FWIW..If you use an on off on DPDT switch for the rock jazz you don't need a separate PAB manual switch as this does the same in the off (center position)..Dumble did this on 124 as part of an upgrade and disconnected the rear PAB switchhalfbackstrat wrote:Right so the Pedal side of the switch is off, without the XLR plugged in. Thank you so much man.
diagrammatiks
Re: OD/Clean
plenty of room for a push pull pot connected to the manual on the front as well.
Re: OD/Clean
Hi,
I gave the former (because useless to have 2 of them) PAB switch at the back the "chance" to switch my RNFB from V1. The right switch at the right place for that IMO
Hans-Jörg
Hans-Jörg
Re: OD/Clean
I should add that when you turn those back panel switches on, they actuate the relays.
So if you have LED's on the footswitch, they will light up as if the footswitch was pressed when you use the back panel switches.
The back panel switches can help if you have to trouble shoot and you don't feel like plugging the footswitch in or other reasons.
Also, the PAB switch is not wired to where it will work right as shown in the #124 layout.
There is a ground missing on the PAB switch.
Here is a layout that I have edited a few things.
Check out the OD/PAB switches to see what I mean.
Remember that #124 has slide switches, not toggle switches.
So for toggle switches, you would flip the wires on the terminals.
In other words the ground goes on the bottom terminals.
On my amp I put the Mid Boost on the footswitch as well.
Re: OD/Clean
Not with the original wiring. There is a separate wire carrying the 12V supply for the LED's in the footswitch, and they will not come on unless the stomp switches are closed.Structo wrote:I should add that when you turn those back panel switches on, they actuate the relays.
So if you have LED's on the footswitch, they will light up as if the footswitch was pressed when you use the back panel switches....
Re: OD/Clean
Really?
Must be the way I have my footswitch wired then.
I believe this is the way I have my foots witch wired.
When I throw the switch on the back panel, it lights up the corresponding LED on the footswitch.
halfbackstrat
Re: OD/Clean
Thanks for that info Tom, I had read something before about errors in the layout's provided. So i have worked exclusively from photographs of 124 and the circuit diagram. I was going to replace the slide switches with SPDT switches which i think should serve the same purpose. Really i don't want to use a foot pedal at all, as i won't be using the amp live, i might revert to a foot switch if i did a no compromises amp, but seeing as this is my first build it's probably not worth it.
As a matter of interest, i live in the UK, so obviously the current power transformer, 022756 from at Fender Twin/Showman, isn't suitable as this is a 120V transformer. The mains in the UK is 240V. What is the transformer of choice for replacing the current transformer.
Also is there any other modification to the amp i would need to do for the UK? I can't see anything or any reason why, but i thought i should ask incase i have missed something glaringly obvious.
Matt
Re: OD/Clean
There are export versions of the Fender Twin Reverb power transformer available from Hammond (made in Canada, and sold by, among others, Antique Electronic Supply in the US) and also from Mojo Musical Supply. Mercury Magnetics also has appropriate voltage models. Tube Amp Doctor lists this one: http://www.tubeampdoctor.com/en/shop_Tr ... an_100_111 Of course the relay supply transformer will have to be 240VAC too.
I'd wire it for the footswitch and put the jack on the rear panel. The footswitch itself can be left 'til later if you like.
Tom, the difference in your wiring is in the amp, rather than the footswitch, I believe. The way you have it would be useful- it'll tell you from the footswitch if the manual switch is on.
Last edited by martin manning on Sun Jun 05, 2011 9:30 am, edited 1 time in total.
Re: OD/Clean
[quote="halfbackstratThe mains in the UK is 240V. What is the transformer of choice for replacing the current transformer.
Thanks[/quote]
I used the hammond 291dex which works a treat in my build, try http://www.bluebellaudio.com/ ,very helpfull and very quick to deliver
Thanks[/quote]
halfbackstrat
Re: OD/Clean
Thanks very much for that link jestaudio, i think i will use the 291 FEX from that site as it has the exact voltage ratings that are specified on the schematics, 6.5V 320V and 60V.
Thanks for your reply Martin, I think i agree with you, the best course will be to wire as standard with the XLR socket and use the sliding switches (SPDT switches in this case) as on/off instead.
Matt
