MM Matchless Footpedal PT for D-Lator?
trane34
Hello all! I wired up a Mercury Magnetics Matchless Footpedal PT using the one of the d-lator schematics here on the board. My voltages are only 250 and 245. Will these work? If not, how can I raise them? Thanks for any help y'all can give.
Re: MM Matchless Footpedal PT for D-Lator?
Those lower volatges changes other circuit parameters. First I would change that 15K to a 1K and see what the voltage is at the first filter cap.
TM
TM
Hi,trane34 wrote:Hello all! I wired up a Mercury Magnetics Matchless Footpedal PT using the one of the d-lator schematics here on the board. My voltages are only 250 and 245. Will these work? If not, how can I raise them? Thanks for any help y'all can give.
do you have no loading cap? Only 2 filter caps?
The 15 k to 1k. But thats already written
Hans-Jörg
- glasman
You can also try using a bridge rectifier with the transformer. Should give you a better chance at hitting the required voltages. Should deliver close to 400VDC using a bridge. With 20ma of current, you have more than you need. Total draw for the loop is on the order of 2.5ma or so.
Definately add a cap after the diodes to help keep the DC level up help in the regulation.
About 5 miles south of I-94
www.glaswerks.com
www.glaswerks.com
