Redplate Magic Dust Duo
boldaslove6789
Post by boldaslove6789 »
I played a Redplate Magic Dust Duo at a friends house the other day.
As per forum rules here is a breakdown of the amp (to the best of my knowledge) . I included a clip, which may be a somewhat poor representation of what this circuit is capable of but I included it anyways
The amp has HRM and NON-HRm Overdrive, Single control clean tonestack with a Rotary Knob to switch different voices (Tweed, Brown,Blackface) and a Buffered effects loop (D-lator).
To my knowledge (please correct me if I'm wrong Henry :) ) the HRM tonestack has the OD trimmer (AKA Trigger), OD Gain, and OD Volume as well as Treble, Middle, and Bass Controls with MID and Preamp Boost.All on the front panel
The NON-HRm has the same OD trimmer (AKA trigger), OD Gain, and OD Level controls but with no tonestack.
As well as being able to use both Overdrives (1 & 2) cascaded into each other.
The Clean has One Tonestack control, and the Rotary knob with 6 positions of Tweed,Brown, and black face voicings.
The Buffered effects loop does not have send/return controls but is set so that you can thow whatever you want in the loop with no need to muk around with levels to balance everything out, just grab and go.
Youtube Clip:
http://www.youtube.com/watch?v=uSpCa2qxYtQ
heisthl
Re: Redplate Magic Dust Duo
Post by heisthl »
pretty accurate description - the front end is tweed based with a way to cut mids and preamp output to get the black and brown modes. The overall preamp output has to be reduced to feed the overdrives. There is no traditional master , in fact one of the mods on the RedPlate site (Mod#2) is to add a couple of resistors to simulate a 1MA set at noon for a pseudo master. The loop does have an internal trimmer for a send (factory set like a 250kA pot at noon) and the return is the front panel control labeled Master.
Here's a gut shot of a CosmicDust (same amp with 6V6 outputs):
www.RedPlateAmps.com
bluesfendermanblues
Post by bluesfendermanblues »
Henry, your amps sounds really great.
Cliff Schecht
Post by Cliff Schecht »
I'm very impressed with the innards of the amp. It looks cleaner inside than most Dumble style builds people post. And that's not calling those builds sloppy, it's saying that yours is very clean!
Cliff Schecht - Circuit P.I.
bolomule
Post by bolomule »
great playin and tone. right up my alley. you just need some terrapin licks in there 8) btw this hits some tones I haven't heard from other clips of this amp. makes me want to check one out.
bluesfendermanblues
heisthl wrote:pretty accurate description - the front end is tweed based with a way to cut mids and preamp output to get the black and brown modes. The overall preamp output has to be reduced to feed the overdrives. There is no traditional master , in fact one of the mods on the RedPlate site (Mod#2) is to add a couple of resistors to simulate a 1MA set at noon for a pseudo master. The loop does have an internal trimmer for a send (factory set like a 250kA pot at noon) and the return is the front panel control labeled Master.
Henry, as always - great tones coming out of your amps!
Just took a look at your 'mod #1' also....why do you lift the V1 cathode ground with a 47ohm resistor. Is that front part of the amp producing ground loop noise in particular?
67plexi
Post by 67plexi »
Henry, Nice clean build. Jaxon & Belle love it. :D
groovtubin
redplate
Post by groovtubin »
AWESOME HENRY! I hear my fav git player EJ in there!
jim
Great amps Henry, your amp line is increasing quite rapidly! :)
I love that amp!
Good review Greg! :D
heisthl
Post by heisthl »
bluesfendermanblues wrote: Henry, as always - great tones coming out of your amps!
Mod#1 is signal path - not cathode. HH
CHIP
Post by CHIP »
Great clip, Great amp.
Greg,What speakers are in the cab?
heisthl
Post by heisthl »
67plexi wrote:Henry, Nice clean build. Jaxon & Belle love it. :D
Daisy and Maddie helped:
boldaslove6789
Thanks guys!
CHIP wrote:Great clip, Great amp.
Suprisingly it's just an Eminence Swamp Thing in an Epiphone Valve JR. 1x12 cap. And It was Loud too!
boldaslove6789
BTW Henry,
The amp looks and sounds just as good as it looks inside :) Kudo's
