 } and the original trafo mounts are bent up.  Anybody know where I can find brackets for vertical mounting a Twin reverb OT? Looked all over, considered making my own out of alum.
 } and the original trafo mounts are bent up.  Anybody know where I can find brackets for vertical mounting a Twin reverb OT? Looked all over, considered making my own out of alum.Where to find twin OT mounting brackets
- boldaslove6789
I'm doing a Bassman 100 to ODS conversion without the OD {two seperate era preamps (classic & skyliner) into a BM pwr amp with a tube loop  } and the original trafo mounts are bent up.  Anybody know where I can find brackets for vertical mounting a Twin reverb OT? Looked all over, considered making my own out of alum.
 } and the original trafo mounts are bent up.  Anybody know where I can find brackets for vertical mounting a Twin reverb OT? Looked all over, considered making my own out of alum.Greg D.C.
Can you dig it?
(NEW VIDS here!!) http://www.youtube.com/user/GDClarkProject
http://quinnamp.com/ http://www.prairiewoodguitars.com/
http://www.funkymunkpedals.com/
						Can you dig it?
Re: Where to find twin OT mounting brackets
Stanley makes all kinds of 1 '& 1 3/8 steel braces..they sell at Lowes/Depot..Not the best looking but work
Aluminum will fracture when you bend it. Use ½” wide steel stock. I used 01 tool steel on this Dagnell  C1998 OPT. The reason for mounting the Dagnell on its side was clearance issues, The Dagnell is ½” taller than most Marshall Style and Marshall OPT. But it sounds cleaner than any iron I have used so far.
EVH was on to something with his famous Marshall #12000 series that used a Dagnell C1998.
Sorry to get off topic aluminum may be fine with a fender OPT it doesn’t weigh 11 pounds.
Steel is easy to work with; pig iron at the hardware store should work fine.
If you go with aluminum use a cobalt drill bit and lemon pledge spray wax for a lubricant.
Have fun, Steve.
Have fun, Steve.
Transformer mount photo.
Here are some pre-made brackets, but this may not fit your transformer. Otherwise you will have to make some from metal stock.
http://www.classictone.net/40-18036.pdf
Like others said I used angle brackets from hardware store.  This picture is a JTM45 tranny mounted with hardware brackets.
						- boldaslove6789
Thanks guys.
									Greg D.C.
Can you dig it?
						Can you dig it?
Mark, you cannot just throw something like that out there and walk away - inquiring minds NEED to know...M Fowler wrote:Like others said I used angle brackets from hardware store. This picture is a JTM45 tranny mounted with hardware brackets.
 What is it?
Curious,
George
P.S. Thanks!
That is my Root 66 I built a long time ago, don't you remember?
I used JTM 45 iron so it's not ultra linear OT like Dr Z used but the amp sounds so I didn't want to get the right ones for it. Nice mellow tone running KT66.
