These were just released by New Sensor Tung Sol KT-120..Drop in replacement for 6550/KT88 a whopping 60 watt plate dissipation..120w out of a pair...Think I'm in love
If you find yourself ordering a quad.. Seek Help..http://www.hearsource.com/?gclid=CKT99P ... NAodNR3KHA
New Sensor now announces the Tung-Sol KT120, which has a plate dissipation of 60 watts, making it the most powerful tube in the 6550/KT88/KT90 family. A pair of these tubes in push-pull configuration can deliver power levels of 150 or more watts. When used at the parameters found in existing 6550/KT88/KT90 circuits, the Tung-Sol KT120 is impervious to overload, delivering peak power with extreme reliability and long tube life. However, taking advantage of the higher current handling capacity of these tubes, a very unique and super powerful and stable amp can be designed using the Tung-Sol KT-120."
talbany wrote:These were just released by New Sensor Tung Sol KT-120..Drop in replacement for 6550/KT88 a whopping 60 watt plate dissipation..120w out of a pair...Think I'm in love
So what would the ideal PT spec out at voltage wise, for P-P amp and a pair of these?
A friend wants me to build him a big powerful amp with mega clean and a switchable crunch. Maybe a low plate clean pre with a higher plate OD channel. He also wants a built in effects set up, (maybe a TC or Lex unit installed in the same head cab through an internal loop) with multi FX capability.
The KT 120 sounds like the animal to use!
What ya think?
guitardude57 wrote:So what would the ideal PT spec out at voltage wise for P-P amp and a pair of these?
What ya think?
We used the Orange ( partridge spec) 120`s @ M Mag building for Electric Amp..B+ 500vdc on plates.. 1K screens Ran it like a EL-34/6550 set-up.
Here's a little more info on these beasts from the latest Lord Valve catalog :
"REFLEKTOR/TUNG-SOL KT-120 (NEW!)
This is the meanest-ass power tube I've ever carried.
I ain't kidding! Massive plates, rated for 60 watts (!)
static plate dissipation. Rated for 850 VDC plate,
600 VDC screen in tetrode operation, a pair of these
in a circuit designed around them can produce over 150
watts RMS of output power. What this means is that they'll
take *stupid* amounts of abuse when used in circuits
designed for KT-88s or 6550s, and shrug off overloads
that would destroy lesser tubes. They'll also increase
output power in these applications, although not by a huge
amount. Note that the rated filament current for this
tube is 1.8 amps - twice that of a 6L6, so these aren't
drop-in for most 6L6 amps; the EL34 filament spec is
1.5A, the KT-66 and the 6550 are 1.6A, so the extra
current required for the KT-120 will probably not be a
problem in those cases. "
