Using RN65Ds on both plate and Cathode?
				Joost
- Location: The Netherlands or Holland. Whichever you prefer
I ordered my parts for a 124 build and saw in the schematic that the cathode resistors should be 1% metal film Mepco/Electra. But since I couldn't find them, I also got RN65D resitors for the cathode. Is that ok? Would it matter, metal film is metal film right?
						Re: Using RN65Ds on both plate and Cathode?
I could be wrong, but you wouldn't think so. Metal films are metal film resistors.
									Yours Sincerely
Mark Abbott
						Mark Abbott
				Joost
Yeah, I thought that too, but what trips me up is that HAD used different metal films for the plate and the cathodeMark wrote:I could be wrong, but you wouldn't think so. Metal films are metal film resistors.
That's fine cathode resistor's aren't a huge deal.Joost wrote:I ordered my parts for a 124 build and saw in the schematic that the cathode resistors should be 1% metal film Mepco/Electra. But since I couldn't find them, I also got RN65D resitors for the cathode. Is that ok? Would it matter, metal film is metal film right?
I usually use some brand of metal fim there.
The Mepco/Electra he used there are long gone, so good luck finding them.
- glasman
The primary reason for using a metal film in the cathode is for temperature stability.   Just use a decent quality MF resistor,  Dales, Koa etc.  Stay away from Xicon MFs,   just my experience,  but I find they add a nasty edge to the sound.
About 5 miles south of I-94
www.glaswerks.com
www.glaswerks.com
I like to use the Dale CCF60 there.glasman wrote:The primary reason for using a metal film in the cathode is for temperature stability. Just use a decent quality MF resistor, Dales, Koa etc. Stay away from Xicon MFs, just my experience, but I find they add a nasty edge to the sound.
TM
My choice too! Nice resistors!ToneMerc wrote:I like to use the Dale CCF60 there.glasman wrote:The primary reason for using a metal film in the cathode is for temperature stability. Just use a decent quality MF resistor, Dales, Koa etc. Stay away from Xicon MFs, just my experience, but I find they add a nasty edge to the sound.
TM
				Joost
Yeah, that's what I thought too. But apparently, on the anode side, the brand of metal film does influence the sound (which makes sense), so I just wanted to make sure.glasman wrote:The primary reason for using a metal film in the cathode is for temperature stability. Just use a decent quality MF resistor, Dales, Koa etc. Stay away from Xicon MFs, just my experience, but I find they add a nasty edge to the sound.
thanks!
I like the CCF60 resistors as well.
Don't get any of those PR01 resistors. Even though they are spec'd for 1 watt they are tiny and about the size of a normal 1/8 watt resistor.
				Drumslinger
+1 as well for the CCF60s.
				tele caster
Any opinions on the CMF60's, that the tubedepot sells?
Yeah, I've used those micro RN65D like resistors a couple times at the cathode location, no complaints. Matter of fact, at my most recent TD order I picked a few of the 1.5k's again for that purose.tele caster wrote:Any opinions on the CMF60's, that the tubedepot sells?
