Filtercap through chassis?
Joost
Location: The Netherlands or Holland. Whichever you prefer
Post by Joost »
This filtercap through the chassis near the relay boards has me confused. I am working on drawings for a custom chassis and and the layout shows an electrolytic cap through the chassis, but the commercially available chassis don't seem to have a hole for them?
Also, this picture of a 124 build doesn't show it. What is the correct answer?
[img:387:401]http://www.familieassink.com/documents/chassiscap2.jpg[/img]
[img:560:840]http://www.familieassink.com/documents/chassiscap1.jpg[/img]
[img:639:425]http://www.familieassink.com/documents/chassiscap3.jpg[/img]
[img:1024:768]http://www.familieassink.com/documents/chassiscap4.jpg[/img]
erwin_ve
Re: Filtercap through chassis?
Post by erwin_ve »
In #124 there is a can cap;
If you use F&T caps on the filter board you have some room for the other filter nodes. Sprague's are insane big.
talbany
Post by talbany »
#124
E.. Ya beat Me.. :evil:
erwin_ve
Post by erwin_ve »
talbany wrote:#124
Are you awaking or going to sleep... :twisted:
Joost
Post by Joost »
erwin_ve wrote:
talbany wrote:#124
Thanks, but where can I get that brown part to hold the cap under the chassis?
odourboy
Post by odourboy »
The brown part is the bottom of the cap. All you need is the can cap and a mounting clamp. (And a hole in the chassis if you don't already have one there.)
The clamps look like this:
http://thetubestore.com/ca-lc-clamp1.html
butwhatif
Post by butwhatif »
used to be a can/thru was the only option, nowadays w/ the advent of modern dielectrics, a radial sizewise can be glued inside
Yeah, most of us don't use the can cap such as #124 has.
Modern 20-22uF caps are much smaller in size so you can put four on the filter cap board.
Or build the precision power supply. :wink:
Joost
Post by Joost »
Structo wrote:Yeah, most of us don't use the can cap such as #124 has.
Yeah, I've thought about the precision power supply, but here's the thing. I managed to find some sprague atom caps of the right value for filtering, so I thought I'd use them.
I got some 320uf 350v caps from Steve here on the board and I got these, will these fit on a classic power filter board?
http://cgi.ebay.nl/NEW-Sprague-Atom-Ele ... 2c5847dbaf
http://cgi.ebay.com/NEW-Sprague-Atom-El ... 2eb0cb468a
Unless you tell me the precision power filtering board has significant advantages in tone or build
ic-racer
Post by ic-racer »
CE Manufacturing 20/20uF 450VDC Multi Section Can Capacitor is a good substitute.
https://tubeamparchive.com/download/file.php?id=4211
Joost
Post by Joost »
ic-racer wrote:CE Manufacturing 20/20uF 450VDC Multi Section Can Capacitor is a good substitute.
very cool, but do I need it? or are the caps in my ebay link small enough to go on the board
