Public guts of ODS
Public guts of ODS
http://www.premierguitar.com/Magazine/I ... ecial.aspx
BM with skyline??? The clips don't do much for selling this amp. Clean clip is OK and on 2nd one you can get a bit of the Dumble vibe if you strain your ears. Other 2 sound bad.
Re: Public guts of ODS
Gut shots.
Yeah, I just read and listened to the clips. That last clip of the OD sounds like the amp needs some attention. Very farty sounding.Tonegeek wrote:BM with skyline??? The clips don't do much for selling this amp. Clean clip is OK and on 2nd one you can get a bit of the Dumble vibe if you strain your ears. Other 2 sound bad.
Chris
whats with the air space on the bells of the OT? I have seen that before. Did HAD do that for cooling purposes?
- boldaslove6789
My 100w HRM BM is the same spec (Skyliner, BM PI) but with 6L6's. The OD's sound scape is very squashy but focused, and fat, great for Buckers. The cleans are huge & the bass response of the amp is quite intense with Ev's (In a good way), but I've dug it even more with G1265's lately. At first I wanted to mod the PI to skyliner specs but I'm digging the way the PWR amp sounds now, even with a Quinn 183 pre. Its kinda got the vibe of Erwin_Ve's when using the non-HRm preamp & D-lator.
The clips do not do this amp justice I bet.
Last edited by boldaslove6789 on Sat Mar 12, 2011 4:06 am, edited 1 time in total.
Greg D.C.
Can you dig it?
(NEW VIDS here!!) http://www.youtube.com/user/GDClarkProject
http://quinnamp.com/ http://www.prairiewoodguitars.com/
http://www.funkymunkpedals.com/
Can you dig it?
Tonegeek, The OPT Marshall style is larger than Fender Twin type and has to be mounted on its side
Due to clearance issues, what you see is custom made brackets.
The story I heard is quite different: The transformers brackets were too flimsy to support the transformers and were removed and new ones were put on that would hold the OT's.
I have one of those NOS OT's and I would replace the brackets before gigging it.
I have seen one ODS with a slightly tilted OT....
It would be nice when reviewing an amp they actually have somebody that knows Dumble amps to do it.
He's throwing incorrect information out there.
Plus the clips suck.
groovtubin
my 70`s version KILZ that thing BAD! lol!Tonegeek wrote:http://www.premierguitar.com/Magazine/I ... ecial.aspx
Jim@O
It's not a skyliner stack...it's all bluesmaster from the picture... nothing on the bass pot.
"...& I'm all out of bubblegum"
Tonegeek wrote:whats with the air space on the bells of the OT? I have seen that before. Did HAD do that for cooling purposes?
Looks like Bedrock used the same setup for this BC-50 model.
Yep, thats it and using the washers spreads the mounting centers so that their mounting holes align with the chassis holes.jelle wrote:The story I heard is quite different: The transformers brackets were too flimsy to support the transformers and were removed and new ones were put on that would hold the OT.
TM
I actually considered (and quickly rejected) the idea that it might be a far fetched tone tweak to put some space between the xfrm coils and the covers, kind of like reducing capacitance by removing the covers on humbuckers. Mounting alignment makes much more sense.ToneMerc wrote:Yep, thats it and using the washers spreads the mounting centers so that their mounting holes align with the chassis holes.jelle wrote:The story I heard is quite different: The transformers brackets were too flimsy to support the transformers and were removed and new ones were put on that would hold the OT.
TM
I suspected as much, and your observation at least confirms it is not a Skyliner. Looks like that amp has been modded/repaired judging by all the different pot types. I see some alpha, CTS, etc. I do recall someone saying HAD used what was on hand at the time, so the differences might not mean anything.ampdork wrote:It's not a skyliner stack...it's all bluesmaster from the picture... nothing on the bass pot.
My favorite part is where he says it was part of a "run" of 40 amplifiers with skyline and EL34's. No wonder it takes so long to get one!
