AB763 with extra gain stage
pula58
Post by pula58 »
I love the clean sound of a Fender amp!. Is it possible, or, has anyone here tried, to add a Dumble-like overdrive (two stage) between output of v1B and the input of the Fender reverb circuit? That is, with overdrive switched-out it is a straight-ahead AB763, but, with overdrive switched-in the overdrive circuit sits between the output of the 2nd triode of the Fender circuit (V1B) and the input to the reverb stage.
I love reverb, and gotta have it..and other reverb circuits, to my ears, have not sounded or felt the same as the Fender circuit.
ayan
Re: AB763 with extra gain stage
Post by ayan »
pula58 wrote:I love the clean sound of a Fender amp!. Is it possible, or, has anyone here tried, to add a Dumble-like overdrive (two stage) between output of v1B and the input of the Fender reverb circuit? That is, with overdrive switched-out it is a straight-ahead AB763, but, with overdrive switched-in the overdrive circuit sits between the output of the 2nd triode of the Fender circuit (V1B) and the input to the reverb stage.
That is basically what Mesa Boogie did on their Mark IIC, IIC+, III, IV and maybe even one of the modes in the V. Careful, the part of the circuitry added for the reverb (i.e., mixer network and recovery stage) will totally change the feel of the Dumble tone. The sound will be more compressed and farty with the extra stage and parts.
Gil
thyx
re
Post by thyx »
An honorable attempt...that's how we learn. The best way to know is to try it. I'd consider putting in some kind of a separate "send" control going to the reverb driver (typically a 12AT7 in a BF Fender) from your OD circuit. The levels coming out of your OD circuit will likely overdrive (and distort) at the tank input. Saturation of the tank input = good. Distortion of the tank input = bad.
talbany
Post by talbany »
Personally I would tap the reverb off V1b (before OD) and return back in at the PI/MV using summing resistors..This is how Dumble did it in his later ODSR's
ayan
Post by ayan »
This was my first attempt at Dumble-izing an AB763 amp. It actually sounded really good, if I may say so.
Gil
marcos
Post by marcos »
I would recommend changing the mid pot to 25 k to get a little closer to the Dumble tonestack.Just my 2 cents
Marcos
markusw
Post by markusw »
ayan wrote:This was my first attempt at Dumble-izing an AB763 amp. It actually sounded really good, if I may say so.
Gil
Looks cool 8)
Thanks for posting!
What's the idea of adding the 1n cap to gnd at the reverb pot?
Peace,
Markus
ayan
Post by ayan »
I found it mellowed out the sound of the reverb a bit.
Gil
Gil
Looks cool 8)
Thanks for posting!
Peace,
Markus
markusw
Post by markusw »
ayan wrote:I found it mellowed out the sound of the reverb a bit.
Gil
Thanks for your answer! :D
Do I get it right that the low pass filter (Reverb pot + 1n) shifts to lower frequencies as you turn the reverb down?
Peace,
Markus
ayan
Post by ayan »
Gee, I really don't remember, that was 13 years ago. :) I eventually returned the amp to stock and sold it in 1999 when I built my first Dumble clone from the ground up.
Gil
Gil
Peace,
Markus
thyx
Post by thyx »
Gil
Interesting. What was the idea behind using such large values of resistance just prior to the OD master?
ayan
Post by ayan »
Gil
Great question. The value of the large (4M) resistor was from an actual Dumble which did not have a master volume for the lead channel. The bypass resistor, 560pF, was given to me in error. When I tried that circuit, it almost killed me it was so bright. So I tweaked it, I had the 3.3M pot from the Fender amp and thought I would make a "harmonics" control with it; it worked really well. That amp was extremely unstable, you would let go of the strings of the guitar and it would take off all by itself.
Gil
