Foot switchable fx loop
gary sanders
Post by gary sanders »
I was thinking of putting a relay on the send and return to cut out the loop when I didnt need it.To hush the popping should I use a capacitor across the switch or would it be better to use the high ohm resistors like on the PAB(22M) and mid boost(4.7M)?
heisthl
Re: Foot switchable fx loop
Post by heisthl »
High ohm resistors work - you can actually get fancy with this and diode from your OD relay to the loop relay so it only comes on with the OD.
www.RedPlateAmps.com
gary sanders
I am finally getting around to do this and I am going to wire the relay as the bypass switch is in this:
https://tubeamparchive.com/download/file.php?id=11010
Where should I put the pop resistors?
ChrisM
Post by ChrisM »
Diode across relay coil is enough. If you want add a cap across the switch going to ground.
Other than that use a well filter supply.
gary sanders
cool,easy enough! thanks chris
I wired my bypass switch like this and it doesn't pop when switched.
Bob-I
Post by Bob-I »
Structo wrote:I wired my bypass switch like this and it doesn't pop when switched.
Yep, me too.
