relaise swiching on ODS 124
Hi Gents,
I finalised a D*Clone.
But I´m not sure about the Channel and PAB swiching because there are so different layouts about.
Wich one is realy the latest, I mean :not wrong?
I´m afraid that my tonestack is not correct wired, because I get a lot of hiss while turning the Master on. On s 0 is nothing - on 10 is hauling wich I can manipulate by tonestack.
Is there any layout on wich I can trust. I mean I found a newest one but there was still a failure wich was discussed weeks before on the relaise.
Thanks for help in advance
Hans-Jörg
Hans-Jörg
Re: relaise swiching on ODS 124
Hans..
What is it about the relay switching in this layout that you makes believe wrong or how can I help..
Posted 124 in the files section..
https://tubeamparchive.com/download/file.php?id=11313
Hi Tony,
sorry if I found the wrong words. I´m austrian
what I meand is that there been several discussions about wron wireing especially on PAB. I guess it was grounding. So I had there problems in the beginning with swiching.
In the end I had the ectract of 3 or 4 layouts builded up in one. So it works now, but with a disgusting hiss or low frequence humming wich gets louder while turning Master louder. Therefore I want build tonestack a second time but on 1 layout only. And the def. right one. I mean this one wich has your approbation.
So I think this one above ist this right one.
Thank you
Hans-Jörg
Edit: I see on the layout above, that on PAB relay swich the pin 2 from one side (goes to treble pot pin 3) goes on pin 3 on the other side of the relay
On the other layout for 124 ( 124 Low Plate Classic)
there is no connection to pin 3 of the second side of the relay. Both pin 3 are n.c.
Thank you
Hans-Jörg
Hans
Yes I see what you are saying and I now remember the PAB discussion issues..I remember correcting the problem w/PAB then sending it to IC to post but it never left my out box therefore was never revised on the 124 thread..I know this revision took place since I used the same layout just edited to the low plate classic and the Ford 102 amp..You can take a look at either of those as they are correct ... I will send another copy of the revision to IC again and hopefully he will change it this time..
The relay OD switching for the low plate classic/124/102 are all correct I just took a look...Thanks for reminding me on the PAB I blew it off
Sorry you are still having problems.. Sounds like something's not wired correctly...Good Luck
Thank you for this answer. I thought I´m crazy.
ok. so I´ll follow in case of PAB Relay the R.F 102. Then I´m on the secure side.
I think I hve some wireing problem too. therefor I´ll build the Relaysection new and compare my wireing with yours. Than it will work as I expect.
Thank you
and greatings from Vienna - there is now one Dumble more on this planet - and that is good. This Amp, concerning the sound, is the best one, I builded.
When its finish, I´ll place a picture - from outside.
Hans-Jörg
Thank you
 Hans-Jörg
				bluesfendermanblues
Hi Hans Jürgen,hans-jörg wrote:Hi Gents,
Hans-Jörg
Nice build - I can see we both use the same Chassis supplier - Tube Town - am I right?
Jep, you are right.
Tube Town is a fast supply for Amp builder in Germany, Austria and Swiss.
Hans-Jörg
Hans-Jörg
				bluesfendermanblues
And Dumble city, Denmarkhans-jörg wrote:Jep, you are right.
Hans-Jörg
				Harald.Nowak
Dumbles in Vienna
Hi Hans-Jörg!
Great you finished a Dumble build and you like the sound; I'm also based in Vienna and would be interested to hear it first hand - if you would be willing to show it to me.
I can offer a "Bassman OD" for a test drive - this is how I call my build wich basically is a Bassman (think low plate) with optional channel chaining (and paralleling as well) and some Dumble "genes" (like 40M Feedback on V1b, 220k/500pF grid stop on V1b, snubbers on V2, 4.7u bypass on V1&V2, etc. you get the idea.); if you'd like to get in touch let me know.
Re: Dumbles in Vienna
Hi Harald,Harald.Nowak wrote:Hi Hans-Jörg!
Isee that I have the same "feathers" on mine. Bassman is very interesting too for me. The only thing is that I´M still not finished (see above). I´m still on debuggung. Want say, as long its not finished (for me) incl. headshell, I´m not ready for shareing
 But its great to know about a Dumble fan so near. Give me a bit mor time to get in touch with you (to find out what my next project could be - a bassman is on my long list
 ) The second is that I´m still close to "building (painting) by numbers" - means I´m not shure my builds are very helpfully to yours. Without the accurate layout of Talbany and others here in the forum, I would´nt be able to build this Dumble.
 Thank you all
Hans-Jörg
				Harald.Nowak
Hi Hans Jörg!hans-jörg wrote:I´m still on debuggung. Want say, as long its not finished (for me) incl. headshell, I´m not ready for shareing
Of course, no problem - contact me whenever you feel about sharing thoughts and some test driving; I can provide a rehearsal room every sunday as well for that. Happy building!
Rehearsal room sounds absolutly great. Count on me!Harald.Nowak wrote:Hi Hans Jörg!hans-jörg wrote:I´m still on debuggung. Want say, as long its not finished (for me) incl. headshell, I´m not ready for shareing
I build the tonestack and the swiching now exactly like Talbanis layout - and it works great.
Only the hiss/humm by Master is still there. I found out its on V3. When I mesure with DMF the voltage I can hear that the noise almost stops when I touch grid of V3 (pin 2). I can read on pin 1 326 VDC and on pin 6 302 VDC. Kathode has 60,7 V. And at pin 2 I read 39,2 VDC. Same at pin 7.
Sombody an idea?
Thanks in advance
Hans-Jörg
				bluesfendermanblues
hans-jörg wrote:Rehearsal room sounds absolutly great. Count on me!Harald.Nowak wrote:Hi Hans Jörg!hans-jörg wrote:I´m still on debuggung. Want say, as long its not finished (for me) incl. headshell, I´m not ready for shareing
Sombody an idea?
Thanks in advance
Hans-Jörg
Yes, check out the grounding of the V3/phase inverter, should be close to the speaker jacks.
Hi,
you mean the grounding wire comeing from minus lug of the 1uF via 390 ohm? Should go to ground (chassis) on Return Jack. Right? But Presence is working. I guess somewhere a cold joint on the grid.
Hans-Jörg
Hans-Jörg
Yes the ground from the 390R and 1uF joint to ground.
