Very nice build, man! Please explain the Jesus cap, I don't get it. I had a really long day coming home y'day, 17 hours, no sleep on the plane, and I'm still a bit bagged.
yeah, what's up with the RN65's. I like those on the plates. I've used them in other places but they tend to make the amp sound harsh. I keep it simple with carbon film
Failure is not an option... it comes bundled with the kit.
fp2000 wrote:yeah, what's up with the RN65's. I like those on the plates. I've used them in other places but they tend to make the amp sound harsh. I keep it simple with carbon film
That’s all I had laying around. I plan on changing them but I'm finished with out sourcing parts for a while. The amp sounds great by the way .
What type of Voltage regulator are you using?
What are your relays rated at, 12V?
What is the blue/red twisted wiring that stretched from the Vreg board to the other side of the chassis?
What is the green wire that grounds in front of the Vreg?
Suggestions & other questions:
Check polarity of diodes in Voltage doubler for Rly pwr.
Check that you have a good ground where the Vreg grounds.
Where does pin 3 of your 5-pin DIN jack ground?
The Vreg filters should ground with the Voltage regulator and not with the power transformer.
Try bolting down the voltage regulator. Right now it looks as if there are wires underneath it.
