#0183 Power Trafo
#0183 Power Trafo
Hi all , can be ok one of this PT for #0183 Dumble clone with EL34?
1) Twin/Bassman 013692 (135W version)
2) Tonemaster 026554
or is sufficient the 125P34AX 022756 ?
Re: #0183 Power Trafo
Grtamp, The power transformers you have listed are 5.5 amps max. For the filament windings
You need 7 amps for the filaments on #183.
This is a Heyboer Blackface Twin plus HTS-10359. Jason had custom wound.
The original power transformer was a magic parts, TF-130
This brings up a question that I have never gotten a clear answer to.
Please forgive me for not getting my RCA manual out to be specific on the math. That said, I understand that the power requirements of a 4 EL 34 amp are different that a 4 6L6.
There seem to be a fair amount of Dumbles with EL34 power sections, (183, 204 come to mind) that use the Magic Parts TF-130. Are there examples that used non twin PTs?
I've talked with Magic Parts and the designation TF-130 is their internal part number for the twin PT. Is has always been this way.
Therefore, HAD used a PT that was underrated in his EL34 builds. Does anyone have info that contradicts this?
Eric
Eric
Hi 67plexi , the Heyboer Blackface Twin plus HTS-10359 have 230V tap also?
Related subject -
Would it be possible to mod a DLite to a 50W #183?
PT - Stock DLite Export transformer
Power Transformers Specs: 100v, 120v, 200v, 220v, 230v/240v Primary
325 V secondary taps @300 mA, center tapped (325v-0-50v-325v)
6.3V center tapped @ 7A (3.15v-0-3.15v)
5V & 6.3V @ 3 A (5v-6.3v-0)
50V bias tap
center-tapped heater winding and hum shield.
OT - Marshall Plexi 50W, 2xEL34
http://www.tubeampdoctor.com/product_in ... cts_id=165
Choke 4H - 100 Ohm
50V bias tap
Choke 4H - 100 Ohm
The JTM 100 Marshall power transformer 1203-80 would be my first choice
It has an input voltage of 100v, 120v, 220v, 230,240v
http://marstran.com/InStock.htm
http://marstran.com/Wiring%20Diagrams.htm
I hope this helps. Steve.
Thanks!
...but for a 50W version of the #183. Will a 50W Plexi OT like the one above work? Made for 2xEL34
Johan, The JTM 50 output transformer 789-139 will work out fine
for a 50 watt EL-34 amp.
67plexi , excuse me , have you a wiring diagram of Heyboer you mentioned?
has 230V tap?
has 230V tap?
Steve, unless he going to use a voltage doubler circuit I would shy away from the 1203-80. That PT was designed as a replacement for the 67' JTM100 dual bridge rectifier, 8 "inside" can model. Besides these suckers are heavy, 16 lbs of iron, 5 more than you really need.67plexi wrote:The JTM 100 Marshall power transformer 1203-80 would be my first choice
A better choice would be the 1204-43 (JTM66 45/100), using the 490V tap.
Wiring the 1203-80 secondaries............
TM
It does not have export taps.grtamp wrote:67plexi , excuse me , have you a wiring diagram of Heyboer you mentioned?
has 230V tap?
TM
It's a shame
Hello all,
I have been reading here over and over again, but I am still not sure if we can use the Tonemaster 026554 PT, I think it is also used in the red knob twin. I have an export version I can rebuild to 102 or 183, because I am from europe. Can some one say for sure it is save to use with EL34. Although I have to say, when the twin was still working right, I have tried EL34 in it for some time and have had no problem yet.
André
André
First, do you want to build a 100 watt version?
As mentioned, you should use a PT with 7 amperes capacity on the 6.3 vac filament winding.
For 50 watt amp you should use 6 ampere.
