Hey All,
I was thinking that I might make a little 'insert box' to plug into the preamp out / power amp in jacks with a 1M pot in between. Has anyone done this? Is there a drawing anywhere on this simple wire up?
Cheers, Mike
Effects Loop Master Volume
JammyDodger
The Jammy Dodger
Re: Effects Loop Master Volume
Yes, I just put a volume pedal in the loop. Go in to terminal 1, out terminal 2 and ground terminal 3.JammyDodger wrote:Hey All,
Cheers, Mike
Yes, I use a stompbox with just a pot (plus a switch and a led) inside the loop to control volume boosts during solos.
Mine is custom built but I think electroharmonix has one among their products.
cheers
teo
cheers
teo
I meant something like this
http://www.ehx.com/products/signal-pad
in case you wanna switch it on and off.
