EV 1x12 thiele cab double micing sound test
ericlee
Post by ericlee »
All around 18mm Baltic birch plywood cabinet with the EVM-12L speaker and two inner mic capsules.
This cab is my favourite so far – compact, powerful, tone rich and sturdy.
[img:900:758]http://www.guitarampcab.com/lmcab.jpg[/img]
Here are the sound samples of the two built in mic capsules, one is on and another is off axis. Best result is when both are recorded (PA-ed) together.
[img:500:473]http://www.guitarampcab.com/lmcab2.jpg[/img]
1. Off axis sample followed by same phrase on axis.
http://www.guitarampcab.com/ottest2.mp3
2. Simultaneous recording with both mics slightly paned left and right.
http://www.guitarampcab.com/ottest1.mp3
__________________
billyz
Re: EV 1x12 thiele cab double micing sound test
Post by billyz »
Way Cool .
bluesfendermanblues
Post by bluesfendermanblues »
Great sounds.
I like really dig the clean as is - a backing track would make it easier to evaluate the OD sounds, which would benefit from a little bit of a room mic sound to increase the 3D'ness.
Great sounds
ericlee
Post by ericlee »
Gentlemen,
Many thanks for checking it out.
Cheers
Bob-I
Post by Bob-I »
I love the look of the cab and the simplicity of having the mikes pre-mounted, very cool idea. Can you share the dimensions of the cab and ports?
Total honesty... the cleans would be hard pressed to be any better but the OD is not great. It sounds a bit off, can't describe it but it's not the typical smooth Dumble tone.
ericlee
Post by ericlee »
Bob-I wrote:I love the look of the cab and the simplicity of having the mikes pre-mounted, very cool idea. Can you share the dimensions of the cab and ports?
Sure,
Length – 53cm, Height – 42cm, Depth – 35cm.
Port tubes – L- 17cm, Dia – 10cm.
Baffle recessed from the front grill – 5,5cm
I’m still tweaking OD channel, it will be great. :)
Cheers
What are the mic capsules?
Drumslinger
Post by Drumslinger »
and the SPL on the capsules? nice cab and mic element setup. speaker used?
Bob-I
Post by Bob-I »
Drumslinger wrote:and the SPL on the capsules? nice cab and mic element setup. speaker used?
Speaker is an EVM12L, I'm curious on the capsules as well.
ericlee
Post by ericlee »
Structo wrote:What are the mic capsules?
Don't let that smoke out!!!!!! :lol:
Capsul is a very light, neodymium instrument mic insert, something like Zen 609. custom order in Germany. :roll:
ericlee
Post by ericlee »
Hey Bob, check out the video from 3,16 ! is it smooth enough? :wink:
http://www.youtube.com/watch?v=6QIBB-MSGMQ
bluesfendermanblues
Year, its fine, but that clip's sound is not stemming from close miking the cabinet, but from the camera mic, Right??
BTW the clip show forumite 'pickmaster' or 'Dr. IKA' why the new avater name??
ericlee
Post by ericlee »
bluesfendermanblues wrote:[quote="ericleeYear, its fine, but that clip's sound is not stemming from close miking the cabinet, but from the camera mic, Right??
Hello my man,
Actually all band goes through a PA, so my cab is miked up with ON axis mic and then I have external stereo mic on the camera.
On another video – everything is recorded via PA desk! So my 2x12 cab is miced up with inner slightly off axis mic.
But this amp is 50w head with an ordinary Ceriatone transformers.
http://www.youtube.com/watch?v=uXxwTZCdfzo
My real first name is Ereclee, I’ve just changed “e” to “I”, sounds more Britsh 8)
bluesfendermanblues
Hello my man,
Sounds very good!
However, since christmas is coming up maybe you guys should wish for a (a)live audience :D - real nice band.
Bob-I
Post by Bob-I »
That's GREAT, exactly what I look for in tone (and the playing's not too shabby!!)
