I have the transformers but I'm holding off on mounting them since they make the chassis so heavy to work on.
The chassis is from the last run of CE chassis.
[img:800:212]http://lh6.ggpht.com/_MHnI-B0pJ8k/TMyFR ... G_0649.JPG[/img]
[img:800:189]http://lh5.ggpht.com/_MHnI-B0pJ8k/TMyFR ... G_0650.JPG[/img]
This is a very well made chassis. High grade aluminum with welded corners.
It has a slightly wrinkled black paint job with nice quality silk screened graphics.
I would recommend these chassis to anyone wanting a good chassis.
Not cheap but quality rarely is.
[img:800:343]http://lh3.ggpht.com/_MHnI-B0pJ8k/TMyFS ... G_0651.JPG[/img]
The main board with flying leads. I used stranded 20 gauge Teflon wire.
1/8" G10/F4 Garolite board. Very stiff and bullet proof board.
I made mistakes on the mounting holes and had to fill them with epoxy and re-drill.
Epoxy works great on this material.
I put clear silicone between the mid, bass and treble caps to keep microphonics minimal.
[img:800:600]http://lh4.ggpht.com/_MHnI-B0pJ8k/TMyFS ... G_0665.JPG[/img]
[img:704:528]http://lh5.ggpht.com/_MHnI-B0pJ8k/TMyFS ... G_0667.jpg[/img]
The Sprague 320uF caps are from a forum member.
They are big! So I had to really cram it all on this small board.
[img:800:675]http://lh4.ggpht.com/_MHnI-B0pJ8k/TMyFa ... G_0676.JPG[/img]
The rectifier board. Sprague Atom 100uF/ 100v cap.
Fast recovery diodes with .01uF snubbers. Siliconed to keep things quiet.
[img:800:537]http://lh6.ggpht.com/_MHnI-B0pJ8k/TMyFk ... G_0674.JPG[/img]
I used terminal strips to mount my screen and grid resistors on.
I didn't want the grid stoppers floating in the air that a lot of builders do.
I wanted this amp rock solid.
Dual bias pots so I have the ability to balance the power tubes however I like.
So I can either balance them right on or make a harmonically rich mis-match. I want to experiment with that.
[img:800:440]http://lh3.ggpht.com/_MHnI-B0pJ8k/TMyGt ... G_0669.JPG[/img]
[img:800:230]http://lh4.ggpht.com/_MHnI-B0pJ8k/TMyGt ... G_0670.JPG[/img]
So I'm about to the point where I need to stuff the boards in there and wire the amp up.
I have one more order coming from Mouser on Wednesday hopefully.
I bought the higher end 5 pin DIN connectors with the locking plug.
I have a couple decisions to make about the relays and what all I will switch with the foot pedal.
One thing for certain, I will have one relay that switches the bright cap on when in clean mode but switches off when I go to overdrive.
I have that in my D'lite and like it a lot.
I think I will go for a Deep switch on the front panel but have Mid Boost on the foot pedal.
So PAB, Mid Boost and Clean/OD on the foot pedal.
I still haven't decided how I am going to approach the head shell cab.
I have a nice Oak plank that I may use if I decide to go natural.
Or buy some voidless plywood and make a cab and tolex it.
That will be a first.
Lot of fun!
These amps are a bit of a pain to build.
Not sure I could whip one out very fast but as with most things, experience counts so maybe after a few I could do one in a week.
