I recently got a second amp to compliment my D'Lite build. I picked up a used Tone King Metropolitan...very nice! Very different. Bass almost to a fault.
My D'Lite has been modified so heavily it virtually isn't a D'Lite anymore. It is a low plate version, with switchable Skyliner (that usually stays on the classic setting) and running KT-88s. Also has one of Brandon's Twin OT's.
I've always thought that the bass was a little thin on the clean channel. Now compared to the Metro, it is anorexic. I don't want THAT much more bass, but I would like some. If you were to put some bass back into the clean channel while trying to not affect the OD channel, how would you go about that?
I agree, good first place to start is the bypass caps, going from 5uF to 10uf will make a noticeable difference. V1B coupling cap would be the second option, although I've found this one to have a more subtle effect.
One thing I've learned is to take the amp out to a practice or gig before you decide if the change is working for you or not. I thought for sure after "fattening" up my clean channel that it was way too much bass just playing around in my small office where I build the amps, then took it to a rehearsal in a large room where it was much more balanced. Just a thought...
Bill
wjdunham wrote:I agree, good first place to start is the bypass caps, going from 5uF to 10uf will make a noticeable difference. V1B coupling cap would be the second option, although I've found this one to have a more subtle effect.
Bill
IIRC, I'm already at 22uF on both V1 bypass caps. And yes, I did have to play with the coupling cap going into the OD section because of it.
Thanks for the suggestions, guys. Keep 'em coming.
why not two 22uf in parallel? i believe there are subtle changes from 22uf to 30uf. perhaps the two 22uf in parallel might do the trick or some other combination. just a thought.
If your running 22uf in V1 and it's still not producing the low end (especially with the classic stack) this is strange.. I get plenty of low end from my classics w 10uf Sounds like it could be a loading issue in the switchable tone stack or something in the stack in general..
By Speaker I think they mean, is this speaker/cab combination the right one for your heavily modified amp. I had two cabs and two speakers. For some reason both speakers sounded good in one cab, but only one of the speakers sounded good in the second cab. At least with my 50 watter. Just try other cabinet/speaker configurations, also guitars. Just a thought.
Frank
Failure is not an option... it comes bundled with the kit.
Frank
10uf on C1 and 22uf on 2 did it for me. .05 V1b coupling cap. If the master byp is too big, or no treb bleed on the OD level, it can seem to have a lack of bass.
talbany wrote:If your running 22uf in V1 and it's still not producing the low end (especially with the classic stack) this is strange.. I get plenty of low end from my classics w 10uf Sounds like it could be a loading issue in the switchable tone stack or something in the stack in general..
Okay, I was able to verify the 22uF bypass on V1a and b. Some other pertinent facts:
1. The amp does have a variable treble bleed, and the cap across the master is 15pF. I know that an excess of treble can sound like a lack of bass, but I also think I know how to hear the difference, and that doesn't sound like what I'm hearing.
2. The amp has a similar amount of bass through each of my cabs: the 2x12 Bob Burt, a 12-10 custom cab I made, and a closed back 2x12. I don't think the speakers are the issue.
So...any suggestions as to where and how I can start looking for the loading issues Tony suggested?
Is this some sort of switchable stack you implemented or is classic setting a certain way you set the skyline.. If it's been modified perhaps you could post a schemo or layout on the switching system..
