Precision PS board dimension!
what's the measure of this Precision PS board?
						Re: Precision PS board dimension!
Precision filter supply board size 4 1/2" x 5" will work.
You'll want to watch the spacing on the radial caps to ensure they'll fit within the traces when you enlarge (or reduce) the gif file to fit on the board you're etching.  The majority of 47uF @ 250V & 350V caps have a lead spacing of 7.5MM.  My Precision Power Supply boards are 4" X 4.875":
[img:4928:4123]http://img508.imageshack.us/img508/1865/pps.jpg[/img]
									http://agbamplifiers.com/
Dumble Clone Circuit Boards
I made this for a transparency.
It should be to scale or 1:1.
I use the Ifran Viewer for image printing.
4 x 5"
Always double check anything before trusting it.
The picture is for a BM but the power supply uses the mask I posted.
4 x 5"
here is another one components on and off.. I think it is 1:1 as well but double check
Hope this helps
						Hope this helps
Jason,jborders5 wrote:You'll want to watch the spacing on the radial caps to ensure they'll fit within the traces when you enlarge (or reduce) the gif file to fit on the board you're etching. The majority of 47uF @ 250V & 350V caps have a lead spacing of 7.5MM. My Precision Power Supply boards are 4" X 4.875":
Are these boards available for sale yet?
				Drumslinger
thanks guys.  this will come in handy when building a 100w version.
When I made that image, I did not have any of my own measurements from an original. The board I'm making is going into a "Brandon" chassis and I re-scaled the image for hole-centers of 4.5" x 3 12/32" to fit the pre-drilled chassis holes. The board came out to 4 7/8" by 4 1/32", but again, that is just to match my chassis with pre-drilled holes.grtamp wrote:what's the measure of this Precision PS board?
CHIP wrote:Jason,jborders5 wrote:You'll want to watch the spacing on the radial caps to ensure they'll fit within the traces when you enlarge (or reduce) the gif file to fit on the board you're etching. The majority of 47uF @ 250V & 350V caps have a lead spacing of 7.5MM. My Precision Power Supply boards are 4" X 4.875":
Yes... I should have the website updated this weekend. I have Precision Power Supply, Relay, FET, Relay Power Supply & Bias/Rectifier printed circuit boards. I also have the main board with eyelets. I still need to load most of the boards & take a few pics.
Guys ,thanks very much , these are great works , thanks all !!!
