2nd Generation 50W ODS Period correct Layout
Here is a Layout of a period correct 2nd Generation ODS 50W specimen,complete with part numbers for cap types, resistor types, type coax with specs, FET # for cross referencing and other valuable info.. If you have any questions please feel free to ask. However the source of this info and the series # of this amp and its whereabouts etc must be kept confidential due to request, so don't ask for pictures, Schematics or relevant information pertaining to this particular amp here or in a PM..Thank You!!
This is more than enough info to build a wonderful sounding 2nd generation ODS with all correct specs..Good Luck!!
For the sake of accuracy & confusion I recommend we refrain from calling this a so called 70's amp since we now have the info.. (we don't call 124 an 80's amp) same applys here, it's simply a 2nd generation ODS..
To Clarify
2nd generation "pre-classic" tone stack (1975 – 1978):
Treble: 500KL pot / 510pF treble cap
100k slope resistor
Mid: 250KA pot / .01 mid cap
Bass: 1MA pot / .1 bass cap / .002 soldered between the terminals 2 and 3 of the bass pot and .02 cap soldered between terminals 1 and 2 of the bass pot / 10K tail
Also notice cap types are not the same throughout
When the 2nd generation was manufactured
- pre production ODS with the 3 step OD switch (1968 - 1972)
- 1st generation (1972 - 1975)
- 2nd generation (1975 - 1978)
- 3rd generation (1978 - 1979)
- transition generation (1979 - 1981)
Also attached are pictures of #40 to help w/Lead dress and other references pertaining to layout..
These really are WONDERFUL sounding amps and recommend them highly!!
Enjoy All..:D :D
To Clarify
100k slope resistor
Enjoy All..:D :D
Re: 2nd Generation 50W ODS Period correct Layout
More 40 pictures and Steve Lukather's 2nd Generation ODS
That really looks nice Tony.
As one that has ventured into Visio just a bit, I know how much work one of those layouts is so thank you very much for your effort.
That should answer a lot of questions.
Tony,
Many thanks!
Michael
Many thanks!
Michael
Me: Just one more...
Thank you so much!
Take care,
Markus
Take care,
Markus
Thank you so much Tony.Very nice and detailed layout.
Thank you very much............ this is way cool
Eric
Eric
Drumslinger
Tony,
superb sir and many thanks.
Nice!
Do you have a serial number range for this circuit?
Man, that is nice. thanks much!
Great work Tony thank you very much.
thanks tony ,awesome job
Thanks Tony, I'm all dressed up (minus the Calrad relay) and no where to go. I just need a better chassis than's what's available and I'm ready to pull the trigger.
Mike
Mike
ICic-racer wrote:Nice!
The roundabout range is between #010 and #060.
Before are the 1st generation "pre-classic" ODS from #001 (Alexander's, he still has it) to around #010.
After 2nd generation "pre-lassic" comes 3rd generation "pre-classic" ODS from around #060 to around #075.
Then the transition generation "classic" ODS from around #075 to around #095
Then the 4th generation "classic" ODS from around #095 to around #140
Then the classic >>> "skyline" transition generation ODS from around #140 to around #155
Then the 5th generation "skyline" ODS from around #155 to around #200
Then the 6th generation "skyline HRM" ODS from #200 to current
originlly made "bluesmaster" ODS you will find in the #155 to around #200 5th generation series number range.
Hope This Helps!!..
Glad everyone is enjoying the layout..
Mike good Luck on that build
- David Root
Wonderful work Tony! Thank you so much.
