D-lator in amp chassis finish
sergio
Post by sergio »
Hi , I finish my D-lator and this are my voltages:
Drive side: 258V / 29V
Recovery side: 228V / 1,8V
I seem this voltage ok
comment are appreciated
Sergio
Tonegeek
Re: D-lator in amp chassis finish
Post by Tonegeek »
sergio wrote:Hi , I finish my D-lator and this are my voltages:
Sergio
Seems ideal
Pitcher Amplification
http://pitcheramps.com
glasman
Post by glasman »
They look very good.
It is good to have the headroom on the cathode follower. That is nasty a$$ sounding clipping that can occur at that stage.
I keep thinking I am going to tweak that circuit for a 12AT7 for a future amp. The 12AX7 really limits the BW. With an AT7 you can take the response from DC to Daylight.
Gary
About 5 miles south of I-94
www.glaswerks.com
Bob-I
Post by Bob-I »
glasman wrote:They look very good.
Gary
What values would you modify?
glasman
Post by glasman »
On the CF if would the cathode and bootstrap to rebias the tubes. On the recovery side I would dump the FB, drop the input resistor value a bit and change the cathode resistor to get the proper bias level.
For the actual values I would have to sit down with the tube data and work out the required "R" changes.
Gary
www.glaswerks.com
BobW
Post by BobW »
Gary, since there seems to be sufficient gain do you see any advantage going to a 12AU7 as well? Am thinking in terms of less gain vs. more bandwidth but don't have the data sheets at hand (until I get home).
