4 ohm’s. 1970 twin output transformer and choke. Loud as hell. I’m happy.
Second #124
Second #124
Thanks to all this build is a 100% killer. I started out with JBL’s then EV’s then rewired my Marshall cab to
Re: Second #124
Looks authentic. Glad to hear it sounds killer. i am hoping to get the same thrill from my Twin (really '70 Dual Showman) conversion to #124
Re: Second #124
Nice looking build.
Is that chasis from the recent run
Re: Second #124
Nice build, Did you decide against installing the FET input?
Re: Second #124
What value PI plates did you use?? Is that a 91K on the non inverting side?
Re: Second #124
The gut shot is not of the finished amp it is stock #124 layout. The fet is installed. The only change is .0047uf On the rock-jazz switch. And the input on v-1 is 22k. The b+460v. Used a 3k instead of 2k2.
V1 triode
V1a plate, pin 6, 196v
V1a cathode, pin 8, 1.66v
V1b plate, pin 1, 194v
V1b cathode, pin 3, 1.63v
V2 triode
V2a plate, pin 6, 218v
V2a cathode, pin 8, 1.8v
V2b plate, pin 1, 216v
V2b cathode, pin 3, 1.82v
V3 triode
Input-side of plate, pin 6, 300v
Feedback-side of plate, pin 1, 299v
Bias voltage -47v
Fet drain voltage, 11v
V1 triode
V2 triode
V3 triode
Bias voltage -47v
Re: Second #124
Tom, the brown plate resistors are IRC GS-3 metal films, probably the 3W 1% line. Very warm and natural sounding without excessive detail.Structo wrote:Nice!
What kind of resistors did you use?
Re: Second #124
Steve
Congrats man.. Sweet build.. Enjoy the fruits and nice plate caps..
- David Root
Re: Second #124
Don't you love that old iron?! What PT did you use?
- David Root
Re: Second #124
double post.
Re: Second #124
Got to love the Mallory TC filter caps. I set a sprague atom to show the larger size of the Mallory. The amp sustains for 13 sec. Blows me away.
Just scored a 1969 twin iron set for the next build. This #124 build scares
me, soon it will be woodsheading time on the guitar.
Thank's to all.
Thank's to all.
Re: Second #124
Yes those are some rather large caps, I can't find any of those old orange TVA caps in the right size oh well.
Good score on the Twin iron.
Re: Second #124
AFAIK F+T build or at least can build exact replicas: http://www.ftcap.de/seiten/en/home/home.phpM Fowler wrote:I can't find any of those old orange TVA caps in the right size oh well.
Max
Re: Second #124
they seems little in dimension also!
