Brown Note ODF-100 trimpots.
Blix
Post by Blix »
I have a killer sounding BN ODF-100 and while opening it up for checking the bright cap value on the mv, I noticed 4 trimpots on the main circuit board, which you can see in the following photo's:
[img:1024:683]http://farm5.static.flickr.com/4078/486 ... 29b1_b.jpg[/img]
[img:1024:683]http://farm5.static.flickr.com/4137/486 ... b24f_b.jpg[/img]
Anyone have an idea what they can be? I have tried to email Moss several times for more info on my amps build, but he doesn't answer...
Re: Brown Note ODF-100 trimpots.
Blix wrote:I have a killer sounding BN ODF-100 and while opening it up for checking the bright cap value on the mv, I noticed 4 trimpots on the main circuit board, which you can see in the following photo's:
Nice looking amp!
Left-to-right:
1) Phase inverter balance
2) Presence control (is there one on the front panel?)
3) Treble bleed at the output of OD stage 2
4) Drive level for OD stage 1
My put based on knowledge of the basic D-type circuit and the photo. No direct experience with BN.
Blix
Post by Blix »
Nice looking amp!
Left-to-right:
Ah thanks.
More info/pics on the amp, and yes presence on the front. :)
[img:640:480]http://farm4.static.flickr.com/3474/464 ... 10b4_z.jpg[/img]
[img:640:480]http://farm5.static.flickr.com/4050/464 ... dac6_z.jpg[/img]
Front switches are 3-position bright switch, mid and bass.
Switches on the rear are od, midboost and PAB.
Blix wrote:More info/pics on the amp, and yes presence on the front. :)
..Then 2) is more likely a variable feedback resistor to adjust the level of FB. Should have come to that conclusion the first time!
butwhatif
Post by butwhatif »
If i might ask, what's the value of the treb bleed cap in your amp? thx jerry
Blix
Post by Blix »
butwhatif wrote:If i might ask, what's the value of the treb bleed cap in your amp? thx jerry
Sure, it was 47pf.
butwhatif
Post by butwhatif »
On the output of v2b? the poly cap there is too physically large to be 47pf--- must be .001 or .002 ?
Blix
Post by Blix »
butwhatif wrote:On the output of v2b? the poly cap there is too physically large to be 47pf--- must be .001 or .002 ?
Sorry I'm not too technical, but I was referring to the cap on my master volume, as seen here(the inside one)
[img:1024:713]http://farm5.static.flickr.com/4115/487 ... 52a0_b.jpg[/img]
If you want to know the value of something else, I'll find out, but you have to tell me where to look. :)
Are both those cerami caps on the bright switch 47pf?
If so then the total value is 94pf.
But it looks like the one in front has different writing on it.
Blix
Post by Blix »
Structo wrote:Are both those cerami caps on the bright switch 47pf?
The second one says C0 22J on it, if that tells you something.
I guess it means the value is 68pf then.
butwhatif
Post by butwhatif »
that's the bypass cap-the bleed is on the board, next to it's trimpot
Blix
Post by Blix »
Ok, forgive me my ignorance here, while I try to educate myself a little.
That master volume pot have a pull bright switch, and I guess that why those caps are there. I have no use for that bright switch really.
Could I rewire it to do a "bright cap" function on the master instead.
Or as I don't need the bright switch, I could easily move the caps over to the viper on the pot though, and disabling the pull function...
Hmm, decisions decisions... :)
Some input on this will be appreciated.
Blix
Post by Blix »
butwhatif wrote:that's the bypass cap-the bleed is on the board, next to it's trimpot
Aha I get it. It's a .001
butwhatif
Post by butwhatif »
I would keep the functionality you have, but if it's a pia then bypass it, or you could have a permanent byp of the sound u normally use, and an extra bright on the switch--
Bob-I
Post by Bob-I »
Blix wrote:Ok, forgive me my ignorance here, while I try to educate myself a little.
I think you have the answer to the trim pot questions.
As for the bright switch, if you don't use it, and if you're happy with the tone of the amp, just leave the switch off, don't change a thing. I wouldn't move the caps to the wiper, that would put the bright on all the time, which you said you have no use for.
