I was putting two relays + diodebridge + regulator in my clone. When finished it got terrible noise (I had the bridge and regulator grounded to the chasis which I should not have done..). I have searched the problem for 3 days now without solution
Turning the following knobs makes the noise worse: reverb, presence, master, drive, drive volume, tone and boost and bright switches.
The switchable treblecap switch makes a 'pop' sound and also sometimes the midcapswitch does that also.
The amp was working beautifully before the relay project. What I have done now:
I removed the relays + bridge + regulator - no help.
I measured continuity on the pots ground points, they were ok.
I removed and measured the presence pot, it was ok.
Removed the channel switch and did put a new in - no help.
Removed the boost switch and put a new in - no help.
Checked every ground point on the amp, all were ok.
Did change the presence cap to tantalum - no help.
Did change the presence resistor to ground - no help.
Changed different PI + V1 + V2 tube in - no help.
I took preamp tubes out one by one. Clean - no help, od - no help, PI - silence.
I had earlier a similar noise problem when I put the ground wire on the wrong side of the presence pot, it gave same kind of noise, but it is not the case now.
Feel kind of frustrated now
Any kind of info much appreciated,
