One step closer - PS finished
Tdale
Post by Tdale »
The main board I posted a few weeks ago, with the dumbleator included, is put away at the moment. I decided to go with a simple, straight forward Hybrid-A type of amp first. I'll start on the main board pretty soon, but I finished the power supply first.
Yes, I have 330K across the first caps..should probably be 270K but I'll change those later. Also, I don't have a 2,2K resistor for the dropping string, but after having read this forum for a while, I'm pretty sure I'll have to tweak all the dropping string resistors anyway, so I'm going with 1K - 22K - 1K for now.
There is also a B6 that is not used at the moment, than can be used for reverb later, if I decide to add that.
Tommy
