Hello all -
I am referring to the 3-phase, Dumble-like mods for the "normal channel" on Fender AB763 based amps as shown here:
http://schematicheaven.com/dumble.htm
I have tried doing these mods and I could not get the FULLY updated Normal channel (thru mod #3) to output ANYTHING. Has anyone ever tried these mods and "lived" to tell about it?? I know its highly likely I just blew it -- but thought I would ask first before I started over.
BTW - I did all the mods at once (very dumb I know now) before any testing. So I am not asking for specific troubleshooting (yet) - but more just an overall sanity check. (The attached file is mod #3 which I did).
If you have done it - I would really like to hear what you think of the mods and anything that I might do different.
thx.
Anyone successful in doing the Dumble-like AB763 Fender Mods
moonbirdmusic
moonbirdmusic
estes park, co
estes park, co
Re: Anyone successful in doing the Dumble-like AB763 Fender Mods
No but one is a P-P pot so the switch should be good there but the other switch is that on-on-on?
Rob Livesey
I did them on a SF Pro Reverb many years ago. I added a mid pot on the back panel, they did work and sounded pretty good. At least I had the option of something different on the normal channel. I also added a pot to reduce the negative feedback
If I remember right, the channel would drive quite nicely with PAB engaged and the negative feedback turned down. It wasn't full on overdrive, but it was usable.
Rob.
Rob.
Rob Livesey
Manchester, UK
Rob Livesey
Manchester, UK
I did the simple one without switches: kept the bright switch. I put the mid pot in the #2 input hole (I do that to a lot of Fenders). Mine was a SF Super Reverb. Added another option for tone. Really worked well with Tube Screamer. The new owner of the amp really liked it to.
D
D
There are no stupid questions, just stupid people.......
