Two Sunday afternoon Bludo Music Man 6L6 Skyline clips
dogears
Post by dogears »
High Plate, Skyline Stack. Big ass bright cap on master. Loopalator and special cables. A little verb and delay added in mix. ANOS RCA in loopalator. A little clearer than the JJ I had in there. Amp has JJ ECC83S in all three slots. CSA on bridge humbucker.
G1265 speakers, multimiced with SM57 and R121 ribbon.
http://scottlernermusic.com/Bludo/Bludo ... Arca-a.mp3
http://scottlernermusic.com/Bludo/Bludo ... Arca-b.mp3 (done after listening to A, I made adjustments to mic positions)
Pardon clams.... Just a couple quicky takes. More coming.
JD0x0
Re: Two Sunday afternoon Bludo Music Man 6L6 Skyline clips
Post by JD0x0 »
Both clips sounded great! Clip A sounded a bit "boomier" i suspect this was because of the JJ's which in my experience have a bit boomier bass response than some of the tubes im used to (ie. tungsol RI)
It's true i've lost my marbles and i cant remember where i put them
Guitarman18
Post by Guitarman18 »
Great tones as always Scott!
You don't say if you are canvassing for opinions but I'm going to stick my neck out anyway and say that I prefer the second clip's tones more, they seem 'less stiff'. It could be a change in mic placement though or settings or simply the area of the neck?
Paul.
dogears
Post by dogears »
Thanks Paul. Yeah, clip B was much better for me! I adjusted things a little after listening to clip A. I moved the mic a little, and also changed the blend between the SM57 and R121.
Thanks!! Comments are definately wlecome....
Guitarman18 wrote:Great tones as always Scott!
Paul.
makrisp
Post by makrisp »
dogears wrote:High Plate, Skyline Stack. Big ass bright cap on master. Loopalator and special cables. A little verb and delay added in mix. ANOS RCA in loopalator. A little clearer than the JJ I had in there. Amp has JJ ECC83S in all three slots. CSA on bridge humbucker.
Clams....you say Clams.....I wish I had your clams....
Good Stuff!
PM
David Root
Post by David Root »
Awesome! My next two builds are a 50W old timer (#13 or lower) and a MusicMan 700V 100W.
Love that 700V sound! What power tubes are in there? Is that Mojotone/Heyboer iron or original Music Man iron or Custom Funk iron?
BobW
Post by BobW »
I love the top end bloom of the 2nd clip. Nice playing, as always. 8)
erwin_ve
Post by erwin_ve »
Hi Scott,
Spot on both playing and sound!
Me likey the 2nd clip best, more articulate, breathier highs.
bluesy
Sounds.....
Post by bluesy »
magical. Very. (loan me a few clams?)
I want the vowel sound!
________
Herbal vaporizer
blue_lu
Post by blue_lu »
scott, your bludotones always amaze me.
clip b was very cool, the first time I actually really felt the vowel quality everyone talkes around here. only similar clip was brandons ojai clip.
sooo good.
pinner
Post by pinner »
Nice!! At home I liked B better but at work I like A better. Seems like the upper mids are clearer on A. I see you are running it with the bludolater but is it going through the rest of the rack as well? Great playing as always......clams my a## :-)
Hmmm, what kind of cables could these be? :D
